- Joined
- Mar 20, 2016
- Posts
- 12,335
- Reaction score
- 21,431
- Ram Year
- 2015
- Engine
- 3.0 EcoDiesel
If it already exists we should be able to unlock the feature but how? If we copy the ecodiesel setup in theory what else is there?
If your talking about copying the EcoDiesel ECM(05150767AC), your not going to have much luck as it uses an entirely different one than the gassers. You would have to extract the code that runs the PWM output but that could be quite in depth as it monitor s the coolant, oil and AC system. I do know the PWM fan is controlled out of the ECM as several tuners would change the parameters of the fan operation.
The 850 watt PWM fan the EcoDiesel and now the Gen5 Hemi uses would be ideal if you could get the correct signal to run it.
