MarcoFuc
MarcoFuc
Tallahassee
Sounds like an exhaust manifold to me. I just had one of mine replaced because it was cracked. Sounded just like the video you have. I had it to several dealers over the course of 8+ months for what I thought was a manifold issue (sound wasn’t as loud), but they said it was fine. Took it actually cracking and sounding like that for me to go to another dealer and they found it. They said it was probably a slight crack/leak before and after driving it for so long, it got worse. That explains the gas mileage loss.
2019 Ram Bighorn
I’ve only noticed a slight loss of mpg it went from 12.8-9 to down 12.1-3 and I have no lights or anything but sides 2 compared to driving in city from my old job, I thought it improve but went down slightly instead.
MarcoFuc
MarcoFuc
Tallahassee
Like was mentioned above, if you don't mind getting dirty, ... get in and around the exhaust manifold with a strong flashlight and an inspection mirror. You can almost always see black traces of exhaust where the leak is occurring (if it's leaking). You may need to remove the front tire and look through the frame and inner fender well.
I removed the inner fender, my truck is lifted so I got plenty of clearance even with the wheel in there, I tried doing soapy water on the studs and didn’t see any bubbles on the studs, but the heat shield is in the way for further inspection, I also didn’t notice any black residue on the top but I can’t clearly see the bottom, but I’m doing a thicker oil change like suggested and see if I notice a quieter tick/ disappearance of it after the oil change. If no sound difference I’m removing the manifold and inspecting for a crack/ gasket failure.
randysgarage
Tennessee
I know a guy that has been repairing a lot of hemi cylinder heads of late. He tells me the valve seats are coming loose in the heads because they weren’t machined deep enough from the factory. I’m pretty sure they would “tick” if they were moving in and out in the heads
Justin33
I got one for you this truck only has 33k miles and is a 15 just using dealer oil changes. I’ve had them check the manifolds at oil changes before as in winter it def sounds louder to me.
How are you guys posting videos I figured I could directly in the site I guess not.
MarcoFuc
MarcoFuc
Tallahassee
Is yours a lifter or exhaust leak? Cause mine doesn’t sound like that at start, mine sounds like a fast tick on start up then slows down to a steady tick.
Justin33
So you could view that video?
Dodge 1500 4X4
Rochester, NY
What kind of manifold gaskets were used when they repaired it last, were the manifolds machined flat, I would use Remflex gaskets when you take it apart.
MarcoFuc
MarcoFuc
Tallahassee
Roger that, to be honest when I did the manifold the gasket and bolt replacement, and one thing I didn’t check to see if it was warped by taking a ruler against see if it was flush going across. The only thing I didn’t use oem was the bolts but i used oem gasket that I got from the dealership but didn’t replace the manifold itself.
WY.Ram
Larkspur, CO
6.4L Hemi
If you replace the manifold with new they will warp again, (and really **** you off, or it would me anyway) I believe the preferred protocol is to take the warped manifold, have them machined flat, and reinstall those. The warping has been done and they have a flat contact surface. Should be good in that environment for the life of the truck.
Then the next time you hear a tick you'll know it's your lifter(s).
MarcoFuc
MarcoFuc
Tallahassee
Okay that’s good to know! I mean I would only replace it if I see any cracks or damage to it. But if that is my issue I might go with jba manifolds, which are top quality and change the bolts so I never have the issue again which I’m hoping. Some people say the jba manifolds are what saved them from ever dealing with broken studs/ bolts or manifold issues.
MarcoFuc
MarcoFuc
Tallahassee
Okay thank you! What imma do this weekend imma buy all this stuff and, to be honest rather have a exhaust tick then a lifter.
So instead of using the redline I went with 5w 30 royal purple synthetic, along with filter and this is what it sounds like now, I hear no difference. I accidentally read your message wrong and thought you typed in royal purple oil but I’ve heard royal purple is good as well so I went with that lol. So my next step is taking off the manifold and seeing what’s wrong with it. https://youtube.com/shorts/aRE-qhEv5us?feature=share
Could be a seal/gasket leak and the bolts are frozen. Gonna have to get dirty to find out. If you want to put it off a little, you could try adding 5w30 redline HP and a rp 20-820 filter, if that is lifter tick one thing is for sure, that combo at a minimum will change it if not erase it out right. If it sounds the exact same, really confirms it is bolts. No reason to fix exhaust tick, you aint hurting anything, if you feel like verifying it isnt the lifters w/o taking off the valve cover there ya go.
EdGs
FL
Do I see oil dripping from around a valve cover bolt? I'm sure not related to your issue.
Can't really see anything with the heat shield in place.
Does your tick get any quieter when fully warmed up?
MarcoFuc
MarcoFuc
Tallahassee
That’s from a drip from when I was doing the oil change, thought it caught it before it dripped down but apparently not. It does not get quieter on warm up. I’ve also changed my oil to 5w 30 full synthetic as well with royal purple filter see if there would be a sound difference or go away nonthing changed. My only option left is to remove the manifold and check the gasket and for cracks. If that doesn’t solve it well I would have no idea what else other then the lifter
EdGs
FL
Ahh, I only caught the shine, Should've said that instead of drip.
When the exhaust manifold bolts broke on my '15, my tick didn't totally go away when fully warm. Those exhaust manifolds can warp crazy, mine were twisted at the rear cylinder on both sides.
Sucks that you have to get in there to see what the deal is. You might be able to see more when the heat shield is removed. Hopefully, you will be able to get it sorted out.
MarcoFuc
MarcoFuc
Tallahassee
That’s how mine got when I replaced them both 2 years ago they got to the point where it would tick even warmed up. I’m just hoping it’s the manifold at this point.
RAM_Larry_15
SoCal
Gents: passing on my recent "tick" experience for my '15 Ram 1500 Hemi (66K miles) - changed the oil to Redline 5W30 and a RP 10-48 filter, it still ticks for a couple minutes when first fired up from cool engine, but then the tick disappears until the next cool engine start. Assume this means a lifter issue? Does this mean I need a cam & lifter replacement? Thx
EdGs
FL
When your engine is cold, reach in through the wheel wells and grab the heat shield at the corners and see if they are loose. If so, exhaust manifolt bolts are broken.
Tick that disappears after warmup is exhaust manifold bolts, most likely.
MarcoFuc
MarcoFuc
Tallahassee
I would assume that it would be a lifter if it only ticks for afew minutes cause oil needs to flow thru, but did it do that before you changed your oil? If so it sounds like a exhaust leak. Mine stays no matter what I changed my oil to 5w 30 royal purple Full synthetic along with the filter and that **** didn’t change **** for me lol
never needs replacement until you get a p0300 range mis fire code, then you need to verify. Try a 20820 rp filter next time if you can. Did the tick chnage with redline at all, or always the same? If it is the same could be bolts.
Redline is different then rp or any oil on the shelf, heavy ep/aw additives, poe ester base stocks, super high mply, most people that try it says it gives their vehicle a butter smooth effect. But as good as it is, it cant do squat if it is exhaust related, only if it is lifter related, and 50% of ticks can be either way.
alphaprojects
