stc315
I've got a 2014 1500 Laramie with 5.7/A8 trans w/133k miles. I'm having issues with nasty lifter noise that I believe is MDS. No noise at start up but after I fuel up and restart I have horrible lifter knocking until I get out on the highway and set the cruise. Then it goes away. I'm assuming its the MDS solenoids sticking causing the lifter to collapse. I'm thinking of trying a tuner to shut off MDS. Does anyone know if the DiabloSport i3 has a function to disable it? It was one of the least expensive options I found, but not sure if the standard tuner has the option or if I have to buy a program for it. I drive 86 miles each way to work (mostly 65-70mph zones). I can't afford to be chasing gremlins. I'm also thinking I need to stock up on lifters, cam, retainers, locks, springs, gaskets etc. so I can be prepared when the lifter fail completely.
Thanks for your time,
Sam C.
Sam C.
