OC455
- Joined
- Apr 20, 2018
- Posts
- 3,326
- Reaction score
- 3,018
- Location
- Central NY
- Ram Year
- 2018, 2019
- Engine
- 5.7 Hemi Big Horn, 6.4L Hemi 3500 Longhorn Mega cab
Got them set up. Got the new Gatling Gun 1.0s trimmed and fitted better than the 1st set.
Was looking at some Switchback strips. There is one made by Acme Dynamo that has a sequential turn signal function that is 16 inches long that I was thinking about running along the bottom edge of the bezel. There is also Profile Pivot that is 18 inches long, which would be too long but can be run to the very edge and can be hidden at the back. The Acme is 4mm thick and 5mm wide, might be a tight fit there. Only has about 20 degrees of flex.
The Profile Pivot is on 1.6mm thick and 7mm wide and would fit there I think with no issue....just that it would be too long. Can't be trimmed.
I think the sequential turn signal/DRL would look awesome run along the bottom front edge of the bezel. But I think it being 4mm thick it won't fit. Or it would be a really tight fit.
Am I off or should I just leave well enough alone and concentrate on keeping the quads clean looking and not cluttered.
Thanks for the input and Merry Christmas.
