New N/A 4 Door Record - 12.49 @ 110.24MPH
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Last night Thad made history in his 2014 Crew Cab by running a 12.49 @ 110.24MPH. He is now the fastest N/A 5.7L 4 Door hemi truck on the books. Previous record was a 12.56 set by a 3rd gen about 5-6 years ago.
Thad's previous best run was a 12.74 @ 108mph 2 weeks ago. The only change since then was the addition of the Moe's Performance HPS cam. He is still running stock heads, stock tq converter, and stock intake manifold. His truck info is below...
2014 Crew Cab 2wd 8sp
Hemifever Custom Tune
Moe's Performance HPS Cam
Track Intake
Moe's Performance 87MM Throttle Body
JBA Longtubes w/o Cats
Dual Magnaflow Cutouts
Catch Can
170* Thermostat
3.92 Gears
Hoosier 28x10x17 Slicks
MADDOG
Living in a Firepit
That's awesome!
hemifever
Apex, NC
He installed the cam on Friday night and ran the startup cam tune at the track. We got a couple of tunes done Saturday right before he left for the track to dial in the fuel trims and we still don't know the full throttle fuel ratio. I'm sure there's some dialing in on this one to get at least another .1 reduction out of it
Lethal Hemi
5.7L
Man it takes a few days to.get a tune down good. So definitely has more in it. Good job!
Housemuzik52
2014 Ram 1500
5.7L
Track Intake
Catch Can
170* Thermostat
3.92 Gears
Are the JBA longtubes and dual magnaflow cutouts installed with the stock exhaust?
Hemi450hp
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
No, he has the longtubes going to 2 Magnaflow cutouts, H pipe, and then 2 Magnapacks.
Housemuzik52
2014 Ram 1500
5.7L
No, he has the longtubes going to 2 Magnaflow cutouts, H pipe, and then 2 Magnaflow bullet mufflers.
That would be so nice to run, unfortunately I'm in Virginia and we have to have CATS to pass Inspection and Emissions.
Are there any other exhaust options for when you can't get rid of your CATS?
Hemi450hp
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I actually prefer a single exhaust myself. If you need cats to pass your inspection, then the ARH longtubes are available with high flow cats in a bolt on application. Very easy install, and with tuning, you will never throw a code.
With custom tuning, we can also eliminate the engine light if you choose to run no cats. Then it just comes down to whether your inspection shop actually does a visual inspection or not.
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
Siiiiiiick. I have a four door. Nice to see this post. I need to just get a custom tune already.
H8Speed
Truck is moving!Can't wait to get my cam in and tune lined out.8 speeds ftw!
Hemi450hp
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Justin, when are you going to put the cam in? The 8 speeds are responding extremely well to the mods, so I have a feeling there are going to be multiple low 12 second trucks in the coming year. You should be right there next to Thad.
