bigolayne
- Mar 22, 2015
- 950
- 285
- Location
- Springfield, MA
- 2015
- Hemi 5.7
Limey here is the one piece you need from Home Depot, you would need two, one for each side. I know you know that but just clarifying. It is a 2" to 1&1/2" rubber coupling. At the top of the 2" portion take a Dremel or cut off tool to cut off the top 1&1/2" reducer. At this point the only thing left is the 2" piece. I then took the dust cover from the Spyders and pushed it up through the bottom. As I have the opt7 with the fan, I used the holes on the top and opened them some more so the wire would fit through. I then put some sealant around the opening and around where the old dust cover came up to make it water and dust tight. You have to cut the top 1&1/2" off entirely or the headlights will not fit back all the way into place.
