FlatbedHemi
Sweet thanks
I'm hoping to get mine back soon
Well, got it back yet?
Sweet thanks
Dang, does that price include the gears? I got quoted $2400 to do mine by several shops around me.
Just an FYI.
I ordered a ProCal from AEV and used it to set the 35 inch tire size and new gear ratio Of 4.88 in my Ram 3500. It made a big difference in the smoothness if shifting, shift points, and power delivery. ‘Noticeable immediately after using it, but even bigger improvement after driving the truck a couple days. I used the ProCal after driving the truck over 500 miles with the new gear change just to be sure the difference wasn’t just the truck learning how to drive once again with the gear change.
I’m sure whatever programmer you use that will set these parameters will work great. I just chose AEV as they seem to be a trustworthy company with good products. I haven’t tried any other unit.
Looks like once you get the speedo calibration done and some extra miles you should do better, but the usable torque is probably phenomenal which I’ll take that over FE since my truck is not my DD
How are you guys towing on the highway. Are you using 6th gear? Is it ok to use 6th gear? I dont know much about auto transmissions but I always heard 6th was "weaker" and we didn't need to tow with it.
I'm scared if I went with a lower ratio and was towing 60+ it would be screaming in 5th.
Right now with 373s I tow in 4th when under 60 and 5th when over.
If I'm on flatter roads, I'll let it hit 6th if it wants, even with my 14k lb 5th wheel. But if it starts shifting down to 5th and back then I lock out 6th with the +/- button or I go to tow/haul mode.
I just dropped it off for the 500 mile oil change haven't towed anything with it yet
Once i get it home i will hook it to my trailer and follow towing break in procedure
I'm thinking by how much better it already feels it will tow much better as well but only time will tell
The main reason for my gear swap is after the last update it was constantly hunting and shifting gears
Any incline whatsoever it was in and out of 5th and 6th unless i locked out 6th gear
I couldn't imagine that being good on the transmission
So far i am pretty happy with the gear swap
I would highly recommend using the tow/haul mode while towing a load of that size.
I keep reading this about the latest updates. I'm keeping my truck out of the dealer for now on. I've got like 4 or 5 recalls (cruise control, tailgate, transmission solenoid, and some kind of front end parts) but I'm scared to get them fixed.
Right now I love how the truck drives for the most part.
