Dusty
- Joined
- Jun 6, 2013
- Posts
- 2,097
- Reaction score
- 2,857
- Location
- Rochester, New York
- Ram Year
- 2019
- Engine
- 5.7 Hemi
The XG10575 is 4.06 H x 2.981 OD. Bypass is 16-20 lbs.Yes, the longer Fram is 10575, I think. Look at my chart.
Nobody I know has test documented the correlation between flow restriction change and media area.
@Wild one and I were chatting about a differential pressure gauge, but it'd take a lot of work to rig up. That kind of effort we would only have done at work with company resources and time.
You can ask members when they experienced lifting ticking starting with the small OEM filter (@Burla and you early members discovered it 1st - I'm merely repeating their observations, which make sense to me).
The XG10060 is 3.33 H x 3.0 OD. Bypass is 9-15 lbs.
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 75612 miles
