Swap from 727 to NP435?
Uncle Booty
Knoxville, TN
5.2L / 318
Hey, guys..
I have a 90 D150 318 with 727 trans 2wd, 3.08 gears. I am considering buying an 82 2wd donor truck for needed spare parts.
The donor truck has a slant 6 with np435. I'm curious about the prospects of swapping the manual into my build truck. Any issues I should know about or ideas on how it would gear out with 3.08 rears and "stock" diameter 235/70R15 tires?
Thanks in advance for any thoughts.
U
Uncle Booty
Knoxville, TN
5.2L / 318
I don't think the slant bellhousing works on the V8.
Hmm... Figures
I'm looking around for a bell housing.. may have found some. Will I need the matching fork or will the one from the slant 6 work?
u2slow
BC, Canada
Cummins 6BTA
Don't know. Never had a slant 6. You have to decide if you want to use hydraulic clutch (88+?) or linkage (87-?)
U
Uncle Booty
Knoxville, TN
5.2L / 318
I didn't anticipate how much a used bellhousing would be. It would be easier to go hydraulic with my cab. Not sure it's all worth it. The 727 shifts good. Just trying to create some fun lol
u2slow
BC, Canada
Cummins 6BTA
Used prices are highly variable. Often a waiting/opportunity game.
My np435 parts trucks have been exceedingly cheap. Also snagged a free pedal setup from a guy that wanted nothing to do with the dodge after he pulled the Cummins.
U
Uncle Booty
Knoxville, TN
5.2L / 318
I've got a line on a 1982 D150 225/manual shift donor truck for parts @ $800. It's 90 miles away and I'm trying to get the seller to confirm whether it has the 435 or 833OD trans. If it's the latter, I will find a way to make it work lol
metalchewy
Las Vegas
2010 TRX4
4.7L
Would likely need a flywheel and 10.5 inch clutch kit as well. Plus all the hydraulics. If the pedal assembly is for linkage would need a torqueshaft (z-bar for shevy folk) and linkage also
/6 is different there.
U
Uncle Booty
Knoxville, TN
5.2L / 318
Am I getting myself into a mess?
metalchewy
Las Vegas
2010 TRX4
4.7L
A bit of one, but it's doable.
If I could convert my '10 to a manual without having todo the re-wiring and fenangling with the CAN bus it'd be worth it to me to switch to a manual.
u2slow
BC, Canada
Cummins 6BTA
I wouldn't say that. I converted my '84 suburban 2wd from auto to a HD 4spd manual ~17 years ago. Wrangle up factory parts and have a similar, longer driveshaft cut & welded to length.
U
Uncle Booty
Knoxville, TN
5.2L / 318
Thanks. It's something I'd like to do. I just need to be patient and learn this stuff. I'm not experienced with Mopar ins/outs (yet).
Hagar1
Ontario Canada
2012 Ram 1500
Hey, guys..
You will need a bell housing and a flywheel.
