Buddy
- Apr 13, 2014
- 2,177
- 984
- Location
- Ottawa, Ontario - cool town
- 2014
- Hemi 5.7
Used engine oil, talk to some farmers. Alot have furnaces in shops that will burn old oil.
From -38 winter to +43 summer (extreme temps of places I’ve been), PUP 5w30 XG11665 filter changed every 8000kms.Not to slide of topic fully. Redline 5w30 is a top choice for the Hemi, what is or are the top for the Pentastar 3.6 crowd? I ask cause I have a '15 200, as does my dad. Have a Baxter cartridge spin on adapter on each with Royal Purple 20-500 filters, and currently have PUP 5W-20 in each. Do the 3.6 crowd run 5w-30 or -20? And Lubegard at all? Or other brand/weight?
I'm gonna be seeing if CT will exchange my stock of 20 for 30.From -38 winter to +43 summer (extreme temps of places I’ve been), PUP 5w30 XG11665 filter changed every 8000kms.View attachment 563389
You dont wanna know, shhh!Where do you guys typically take your used oil/transfluid? I usually bring mine to the dump but they have stopped taking it.
I know most auto parts stores take it, I've just never needed to bring it to one before.
What about coolant?
Waste Management aka recycle binWhere do you guys typically take your used oil/transfluid? I usually bring mine to the dump but they have stopped taking it.
What about coolant?
If you are not hot on using the specified 0W-8, check out some owner's manuals from other countries, just for grins. Try the Australian manual for the same engine. This is where I found the most extensive list of "recommended" viscosities for the engine in my 23 Lexus; NA specs 0W-20 ILSAC GF-6A; Australia specs 0W-20, 5W-20, 5W-30 and 10W-30 SL, SM, SN, SN+, SP or ILSAC GF-6. I'm sure that you know why NA specs 0W-8...........In 2009 we got the rav 4 23,888, we got the cross 24,780 16 years later. Freaking 0w08, yeah two years maintenance free but I will at least go 5w20. No trans dip stick, so this will be fun figuring out changing that. The rav 4 paid off and running like a top, but she needed a new shiney thing. Why tall people can get in out of cross, as you can see it is higher off ground.
If the state does it they are recycling hero's, if you do it you re a climate denier.Ah, the 'good old days' of gramps dumping waste oil on the Class 5 gravel to "keep the dust down", and dad dumping down the toilet cause "they'll take care of it at the sewage treatment plant."
Disclaimer: DON'T do this now!
I heard it from a friend who heard it from someone you were messing around, doesn't move the needle here. We do our own testing here.I watched an iol test and Amsoil was no better that WALMARTS Hi Tec. I think Amsoil is a huge over priced ($10.00 a quart) rip off.
Our old neighbour used to keep all his old oil in a 45 gallon drum,and every fall he'd spray it on the bottom of his truck and car.This was way back in the 60's and 70's,and he probably had the least rusted out vehicles in the areaWhen I was growing up living on a dirt road, I heard of someone that made an oil spreader than fit into 55 gallon barrel **** holes.
150 gallons plus was put onto the dirt road every year. The county road grader operator wouldn't grade that part of the road until the oil was all used up, then grade it smooth so it could be oiled again.
That type we call "Gossip pipe" in Sweden. Because it tells when it is to much.So simple I am impressed.
View attachment 563554![]()
Everything Toyota WS ATF and Lexus WS ATF transmission overflow tube, details cannot be found.
Please support this channel via https://www.patreon.com/user?u=163958185 Reasons to avoid Transmission Flush https://www.youtube.com/watch?v=or9u8DQ4fVUAMSOI...youtu.be
