I am in the process of picking up a 26ft travel trailer, weighing around 5500lbs empty I believe. I am wondering what kind of fuel mileage you guys are getting while towing. I am not expecting great numbers since my truck has poor gas mileage empty. Most of my trips will be short, but I was hoping to do a couple trips out west, but I am not sure it will be economically worth it with this trailer.
There is so much that goes into mileage that everything you get will likely be an opinion or an average, and yours will vary.
Things that go into mileage: driving style, weight of trailer + gear, aerodynamics of the trailer (usually that of a large brick), gear ratio & transmission of the truck, traffic, elevation, fuel used, engine, weight of gear in the truck, etc. etc. etc.
What you're probably going to hear for mileage while towing with a 5.7 in a 2500: Anywhere from 5-10 mpg. 5 means you're likely overloaded or driving too fast, 10 means you are driving pretty slow with a light load.
The biggest issue with anyone on here being able to help you out is you didn't really give us much in the way of info - sure you gave us plenty for the trailer empty, but how much will your gear weigh? You've got a 5.7 Hemi, and that will not get good mileage pulling, though it will do it just fine depending on what gear ratio you have in the rear axle - it could be anywhere from a 3.55 to a 4:10 from the factory.
I'm not telling you all this to be mean or ridicule you. I'm telling you all this because we on the forums (for the most part) really do want to help you, but you have to give us quite a bit more information than you did.
