Transmission fluid dark before 30k Miles
ripping r
Old&Grumpy
earth
6.4 HEMI
well i have the steel fitting thanks to burla. and i planed on a pml pan and now ill get this ats bypass delete. but i have to wounder. i have 4100 miles and 4 more years of warranty left. im sure all these things will end that. not sure what to do.
AFMoulton
Nuevo Mexico
They would have to prove that something you added, caused the problem. Very hard to do especially depending on the state you live in. Mike knows a metric **** ton about Magnuson-Moss Warranty Act, he will chime in soon I’m sure.
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Armory 18x9 +12mm
Cooper St MAXX LT295/70R18
2016 Durango 5.7 AWD 3.07 Amsoil SS 4 Qts 5W-30 and 3 Qts 0W-40
1996 Nissan Altima 2.4 Amsoil SS 5W-30
I cant help you there, my opinion is cold comfort for people walking on warranty stuff.
ripping r
Old&Grumpy
earth
6.4 HEMI
so has anyone installed one of these yet? ats bypass delete i just orderd one. anytips?
AFMoulton
Nuevo Mexico
Just so Kyle can laugh at me again. This is on my 66RFE
ripping r
Old&Grumpy
earth
6.4 HEMI
thanks! very nice. you saw big drop in temps. i hope i see that much. i run 183 empty.
Reactions: U&A
U&A
2016 3500 SRW
6.4 HEMI
Is seems everyone with the 66rfe is seeing an average of 40-50 degree drop. We will see for sure in the summer temps. Im guessing if i run 172 normal i will be at 130’s in the summer.
ripping r
Old&Grumpy
earth
6.4 HEMI
That would be nice. 40-50 degrees and than when i do the deep pan. maybe ill get even lower.
Hemi395
Cape Cod MA
It's been around 60 here so far this weekend and my trans temps have struggled to get to 120 a couple times. When you bypass the TBV your trans will be 130-140 unloaded in the summer.
U&A
2016 3500 SRW
6.4 HEMI
The deep pan did nothing for me in terms of temp. But having more fluid is always good.
ripping r
Old&Grumpy
earth
6.4 HEMI
Its around 100f + here in the summer. so that should be a good test.
U&A
2016 3500 SRW
6.4 HEMI
Keep in mind tho you put that deep pan on before you bypassed the TBV...
Yup.
And i logged months of temps before the pan install. I saw no difference after the install.
Doesn’t mean others wont see a difference. I just didn’t.
But more clean fluid and a drain plug is a GREAT reason to do it.
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Now that my temps are far below the previous average with the TBV removed - I would really be very much content with a stock OEM pan that had a drain plug - That Didn't Leak!
I have read so many horror stories of the Dorman Pans that come with a drain plug, over 85% of them leak at the drain plug.
I'm all for saving $200 but I dam sure don't want a leaking transmission pan.
I might as well just quit concerning myself with the thought and go with my first thought and choice the PML!
I just hate spending that kind of $$$ if there is really no need! :****sweak:
Which reminds Me - I need to stop by Atwoods on the way home and purchase a large jug of Miracle Grow again for that Frickin $$$$ Tree I planted (Out Back) last spring!
Hemi395
Cape Cod MA
Yup.
I didn't explain my point very well, even if the pan did lower your temps at all the TBV closes when the fluid gets cooler than 170 and then the trans heats up to 170 again. Pretty much negating any cooling effect of the pan. Now that you've bypassed that POS you stand a better chance to see some cooling from the pan
U&A
2016 3500 SRW
6.4 HEMI
Now i see,
Sorry sir.
Makes sense
