Truck dies while driving when I take foot off of the pedal.
NebRamOwner
Nebraska
5.9 L
So about a month ago I noticed that my 1997 5.9 L was overheating a bit. After a little investigating I found that I had several issues. The water pump and timing chain cover were leaking. I replaced the thermostat, water pump, timing chain cover gasket, hoses, and the temp sensor. No more leaks and no more overheating. I thought everything was good. For some reason after doing all of this, while driving, if I take my foot off of the gas pedal. The truck will drop to 0 rpms and die. It starts and idles a little rough right away, but immediately levels out and idles fine. I researched a bit, and tried resetting the pcm. That fixed it!..... for a week. Now it is back to doing the same thing. Any ideas?
Gr8bawana
6.7 CTD
Could be the throttle position sensor or Idle Air Control valve.
My '97 would almost die when at a stop sign but not quite. Put in a new AIC and it was perfect again.
