tuneing
bodyman247
wichita ks.
5.7 415 hp
I was about to trade in my 2014 for a 2016 til i noticed the tuners have skyrocketed......why is that? :crazy:
StoneDude76
West Chester,PA
Because you will need to replace the factory ECU for one that is modified on Rams after 2014. No tuner seems to be able to unlock the factory one. So when your buying a tuner for a 16 you get a programmer and new ECU.
Sent from my XT1080 using Tapatalk
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Like said above, the factory PCM is locked on the 2015+ trucks. This means that you need the tuner and an unlocked PCM in order to use the tuner. You can save yourself a few dollars by sending your PCM in to Diablo to be unlocked, but then you dont have a stock one to fall back on in the event of needing warranty work done on your brand new truck.
Kjz3Ro
Midwest city,Ok
You know I thought about doing this and just swapping back to the stock PCM when I went to the dealer but when I was there a few weeks ago to get my the oil changed the guy checking in my truck plugged in a OBD2 port cable that was hooked to his tablet and read the miles and everything from there.. That blew my mind and makes me much more nervous to tune my truck now..
BlownGP
Houston/Baton Rouge
Yup and PCM can count how many times changed have been made to the PCM.
Witch
Hemi 5.7 liter
The good news is I am illiterate when it comes to cars and truck, if they ever quuestion me as far as i am concerned they have a problem with equipment "PMC what ? Sir, I afraid may you need to put a new one in as it is obviously not recording the miles correctly ?
Are you sure your instrument is reading correctly ? "
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
After I read your post, I decided to test this. Guys have said many times that they are worried about the mileage being off when going back to the stock PCM, but I have yet to hear from a single customer that has had any issue with this at the dealer. I just made a run to our local dealership to pick up some gears for stock, and I put my stock PCM back in just so that they could check it. My buddy in the service dept hooked the computer up to my truck, and the mileage read identical to what is shown on my speedometer.
I am not in the least bit worried about my warranty when putting the stock PCM back in.
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
The plot thickens. So, where is the mileage stored if the stock PCM shows the correct mileage that's on Your odometer?
MANual_puller
Shade tree grease monkey
Vinton, Iowa
2011 Moose
5.7L hemi
Mileage has always been stored in the gauge cluster....been that way for a loooooong time.
MANual_puller
Vinton, Iowa
2011 Moose
5.7L hemi
The stock one that's locked cannot be changed and will never count anything. It's as simple as a couple plugs and nuts and the PCM is back to stock for a dealer visit.
