My new-to-me PW wont fit in my garage by about 1-2" (due to the running lights / sharkfin antenna)
I can't part outside due to HOA restrictions, and I cant make the garage bigger.
What would you do (besides sell the truck)
Have an autobody shop install low-pro running lights / remove the antenna? (Any recommendations on low-pro running lights / antenna?)
Or find a suspension shop to install airbags? (if so do you have any recommendations on airbags?)
Any other suggestions? (not trying to air-down every day etc / looking for something more sustainable)
I don't recommend making any major changes to the truck that don't involve lifting it.
If it is just barely not clearing the door, you might be able to adjust the upper stop on the door to get the clearance you need. I have a VERY low door on my garage and was able to adjust the upper limit to get another 2-3 inches of clearance for my old truck. The Wagon just won't fit because of the door header.
If it is the door header is too low, you're looking at likely a couple grand to get that raised professionally, along with a new door, provided you have ceiling height in the garage to accommodate that additional height. If you don't have that, you'll need to raise the entire roof of the garage which, since it sounds like it's attached, means a LOT of work.
Or, just tell your HOA to get bent. Their rules usually won't hold up in court if it comes to that - lots of HOAs have lost cases in court that got pushed.
