AlfaOBD
Jimmy07
Oh Body Computer, dodge 2018, connect and go to the car with the open hood and clear all? Oh okay instead of going to Engine I will go to ABS and go from there?
Instead of body computer or engine, choose abs.
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
When I select the ABS module, these are the things is listed.
1.ABS Chrysler/Lancia/jeep/Ram
MY2006-12 Non-PowerNet
2. ABS Chrysler/Lancia/Jeep/Ram
MY2008-12 Non-PowerNet
3. ABS Bosch/Continental/Teves/Trw PowerNet
MY2013+ PowerNet
4. ABS Bosch/Continental/Teves/TRW PowerNet
MY2019+ PowerNet
5. Integrate Trailer Brake Module (ITBM)
MY2010-12 PowerNet
6. Integrated Trailer Brake Module (ITBM)
MY2013+ PowerNet
So needless to say I was at a lost here so I finally back out and thank you for your help.
Jimmy07
MY2013+ PowerNet
MY2019+ PowerNet
MY2010-12 PowerNet
MY2013+ PowerNet
Yours is number 3-
MY2013+ PowerNet
The instrument cluster will start to chime when you connect to the abs module. This is normal.
Bigdaddy
6.7L Diesel Cummins
Thank you I'm going out now and try that.
Well I did it but now I shut everything down and just waiting.
So what do or when do you do a ABS initialization, a lot of questions I know but maybe it will help other also?
Bigdaddy
6.7L Diesel Cummins
Okay I'm back again and I have it back working like it suppose to and I really want to thank Jimmy07 and Kad so much your help is deeply appreciated.
Bigdaddy
6.7L Diesel Cummins
Okay I need to work on my fuel captivity to see if I can get it to read 52 gals or 197 liters.
CanRebel
Toronto
I mentioned that to him earlier. put lower number.
Had issue with my 2021 rebel with tires. It wouldn't take correct number. I had to go little lower.
Bigdaddy
6.7L Diesel Cummins
Changing fuel capacity doesn’t work on 4th gen HD Rams. It only works on 2019+ HD Rams, and the highest value that is valid and works is 194.000
Lol, you know I was thinking that after I type this that it don't work but I beginning to learn how many miles I can go when I fill up my tank and about how much it will cost to fill it up from full to 3/4 full I'm alright with that and thanks again sir.
hunterdan
SE PA
2019 classic
Has anyone successfully done a quick learn on the 8hp70? When I connect it doesn't give me an option for the 8hp70, just the 8hp45 or the 6 speed.
gapi
Georgia
HEMI 5.7
We purchased a used unlocked Trackhawk PCM and want to write the receiving vehicle's VIN to it. Is this possible?
michael harpe
U.S. Army 2001-2014
quitman, ga
2018 Power Wagon
6.4 hemi
tried doing the foglight drop out disable from https://www.youtube.com/watch?v=pvRAb9G1YHY&list=PLdCjicTh12KSFdkr5IITlDbiHvFWAogXP&index=3&t=362s and the fogs dont stay on when i have the highbeams on. the settings took and show dropout selected to no when i go back into them. i did wait to required 5 mins with the truck off. any ideas? i did switch the fog lights out to led pods and they are hooked up to the factory fog light harness with a y adapter with factory plugs. could it be because they are pods? they work just like factory when the lowbeams and fogs are enabled from the factory switch. 2018 ram 2500 power wagon. i did select the 2018 my body computer. should i try it with the 13-17my body computer selected instead?
Bigdaddy
6.7L Diesel Cummins
Hey guys, I was trying to find a place to put this so if this is not the right place move it for me, but I have a question, I am in the process on getting a new 2022 dodge ram 3500 LB will the OBD+MX work like it does on my 2018 3500, will I need another bypass cable for it to work on my new 2022 ram 3500? Thank you guys for letting me know.
Matt Franklin
Lexington, KY
I think so. Kaodtech’s website lists different parts for the 2018 vs the 2019 up. Might try contacting them through the website or IM’ing on here.
CanRebel
Toronto
OBD will work. for bypass cable. not 100% sure. depends which you have.
Jimmy07
The bypass you have now will work on the 2022 3500, you just need to shave off the key way on the bottom of the green connector. 45CB0F56-9288-4D0B-93D2-E49B13A5316B.jpeg
Bigdaddy
6.7L Diesel Cummins
YES, man you guys are awesome I know that I will be able to get an answer, great and thank you again.
