Do I have a lifter going out? YES, I DO!!!!!!
EdGs
EdGs
FL
EdGs
EdGs
FL
Started cleaning up my heads and valves. Damn, is there an a$$load of carbon in the ports. Knocked a bunch out, then hit with some wire brushes.
I had already gotten a bunch out before this bunch in the intake ports.
I had already goten a bunch out before this bunch in the intake ports.
Damn she'll run like a new truck by the time you're done Ed,lol.That is a fair bit of crud in the intake ports though,are you running a catch can?
EdGs
EdGs
FL
No, not yet.
That's 200k miles, with nothing done to the truck.
EdGs
EdGs
FL
I have a glass top sidebar table, wanna spray-glue several sheets of 600 paper side by side, and figure 8 the head to smooth out the block surface.
EdGs
EdGs
FL
I haven't been able to work on her much this past week. Actually, I havent had the energy.....lol.
Is it ok to use assembly lube on the valve stems when I reassemble them, or just oil?
Assembly lube will stick around till it gets oil up to the top end
EdGs
EdGs
FL
After wire brushing hell outta the ports, then soaking and scrubbing in in LA's Totally Awesome Cleaner and water 1:1
Intake ports 7, 5, 3, and 1
Exhaust ports 7, 5, 3, and 1
Still more cleaning to do, then on to passenger side cylinder head.
Intake ports 7, 5, 3, and 1 View attachment 570828
View attachment 570824View attachment 570825View attachment 570826View attachment 570827
View attachment 570828View attachment 570829View attachment 570830View attachment 570831
Got any finger prints left on the tips of your fingers Ed :Big Laugh: Damn you're doing a good job with cleaning them though:waytogo:
EdGs
EdGs
FL
Here's the passenger side head, untouched.
Intake 8, 6, 4, and 2
Exhaust 8, 6, 4, and 2
Exhaust 8, 6, 4, and 2, valve side
Chamber 8, 6
Chamber 4, 2
EdGs
EdGs
FL
Barely.....lol.
That cleaner leaves my fingers like prunes, and slick, too.
It looked like it might leave a little residue, but hard to tell because the water here is very hard.
I stuck both heads in a tub of water and Dawn dishsoap, think I might let them soak for 24 hours to see how that behaves.
Actually those aren't bad for 200K,i've seen chambers and ports in far worse shape then yours with only 80,000 miles on the engine.That's a testament to using good fuel and staying on top of your oil changes
turkeybird56
Central Texas
Most important said for people to read and adhere to: Run top tier fuel and stay on top of oil changes: not go 7500 or 10000 miles and definitely disregard silly oil % meter. All IMHO.
Mileage directed to gas motors, diesels may be done differently as U talking different stuff like regens and fuel dilution.
EdGs
EdGs
FL
That's wild, because I run 87 almost exclusively, and was changing oil by the OCI up til now, so I guess I was extremely lucky.
Also, less than 9% idle time.
Gonna run RedLine for my first full change, and better gas as well. As well as shorter intervals for oil changes from here out.
EdGs
EdGs
FL
Well, I feel so incredibly stupid. I had a few day delay in cleaning of my heads, and I got sidetracked and left them submerged in the rinse water for a couple days.
At first I thought it started to rust the valve guides and seats, but that was leftover oil residue and some hard water residues and such. I was able to clean it up and oil the valve guides and seats.
So, I started in cleaning the untouched head.
Used up the last of the brakleen I had, and then it occured to me, "Dumba$$, why don't you use some gasoline to clean up the heads?" The gas worked about as well as the brakleen did, except I will still use some brakleen to rinse things off before the head reassembly.
See what I mean about Ed luck? I take the long way around the lake. I get there eventually....lol.
So, not much going on except cleaning, gonna get a few extra gallons of gas so i can give the heads a good last soak. I will have to dispose of the dirty gas with the county, but I have a bunch of used coolant and other stuff I can take there with.
Sorry for the very slow progress, stay tuned.
EdGs
EdGs
FL
Ok, since I had some time, I removed the throttle body, fuel rails, SRV, and pcv valve.
There is some internal stuff to the SRV. Anything I need to worry about while cleaning?
Also a sensor, related to the srv? Does it come out? Didn't want to break something.
TIA
