INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
Wolfpup
Shirley, NY
If it works do not update. Unless you want to update just to see if it fails during the return period. Then you could have some piece of mind that you can safely update in the future. Latest update is 22.6...
i don't want to risk the fail. I got it from a donor vehicle and can't believe how much i saved. it was a great deal.
SitKneelBend
St. Louis
3.6 Pentastar
Then sit back and enjoy. How much did you spend?
Wolfpup
Shirley, NY
$250, no scratches on the screen. I practically stole it. I looked an hour prior and there was nothing under 500 with some scratches. then I looked when i was on my break, and there it was. it was a risk though because the picture didn't show it working, but it had a grade "A" listing.
i've been looking for a long time for something in the $400-$600 range with little or no scratches, just got lucky i guess.
SitKneelBend
St. Louis
3.6 Pentastar
Indeed! Patience typically can get you these at reasonable to great prices.
Wolfpup
Shirley, NY
I’d like to thank the forum for everyone’s successes and fails regarding all the mods and upgrades. I had a basic express with the 5.0 radio as the only option. I have somewhere between an express/ big horn/ sport now with functioning UAS 8.4 radio, ATC, 7” instrument cluster, center console, and power leather heated/ ventilated seats with auto on comfort. I couldn’t do it without all the members before me and Mike and Mike at m2 mods with their wiring harnesses. Money well spent imo. Everything’s great now!
Wolfpup
Shirley, NY
------------- 2018 USA RAM UAS 4C INFO -----------------
2018 8.4 UAS (xxxx) NEED more info. If you have any please share.
Verified P/N's:
- 68331635Ax (USA RAM UAS 4c ) ...
Latest Version: 22.6 (DEALER TSB 08-016-19 RevC D/L )
NOTE: The only files that should be on your Fat32 16GB+ Thumbdrive when ready will be "VP4R_Update" FOLDER.
- v22.6 UAS Fw Link (Good Version) and Update Directions Link
List of changes: 18 Ram UAx v22.6 TSB 08-016-19 Rev_E.pdf (directions also)
MD5: 7FC16A62ED3BA3CED525A80C24F6883C
Will this work for a 2019 UAS 63131635AJ from a 2019 RAM 1500 Classic? the radio manufacture date is March 2019, and has 22.5 on it already. sound is kind of muddy (but I got it equalized ok for now) and the text messaging that comes through is annoyingly loud all the time.
SitKneelBend
St. Louis
3.6 Pentastar
I'm on 22.6 and sound is good but the notification sound defaults to 15 every power cycle. It also seems the notification is much louder than what the other sounds are. I turn it down to 3-5 every trip when it starts talking.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
That seems to be a common complaint with v22.6. ... The fixed the radio audio EQ settings introduced with v21.9 but buggered up the notifications still.
It's a shame they can't get it right because v19.9 was/is perfect.
M² Mods.
Wolfpup
Shirley, NY
It does it for every notification for me on 22.5. If it does it only the one time with 22.6, and I turn it down and it stays down, I’ll be good with that.
DiscoLisS
Delaware
Hemi 6.1
who can help?
Need update for VP3 RA3 FOTA 2014.
I can not put a new one on my firmware. Uconnect_VP3,18.45.01-My13-17
48PowerWagon
Bellingham, WA
DISCLAIMER: I am not responsible for you or what you do with your radio. It is up to you to know if these are correct for you or not. Use these files absolutely at your own risk. I am simply trying to help those that can't get a verified VIN for their 8.4AN swap or want to roll back to previous firmware for some reason.
(CNET) MD5 Checker 2.31 (creator)
(GET IT! You should check your downloads against MD5’s whenever they’re posted to verify a good download.)
2014 8.4AN (RA4/VP4 NA, 68224525AB)
Verified P/N's from members:
- 68224525AB ... Jared 4.7
- 68224525AD ... Tallsilver
- 68224525AE ... (Avgas & LQK Ebay listing)
- 68224525AG ... OutlawTrucker
- 68224525ZH ... SitKneelBend
- 68224525AH ... (Vin Verified via LakelandMotors Parts clerk, CptWing, & Mpgrimm2)
Latest Version: 18.45.01
** FYI. The latest v18.45.01 update for ALL 13-17 Ra3 VP3-NA and RA4 VP4-NA radios is in a separate thread at the moment & appears to require SW version 17.11.x or higher **
ROLL-UP INFO: FOTA 18.11.x & uC D/L 18.45.01 SW Update 13-17 RA3/Vp3-NA & Ra4 VP4-NA.
NOTE: The only files that should be on your Fat32 4gb+ Thumbdrive when ready will be "swdl.iso and swdl.upd"
- v17.43.01 Fw Link (2014 ONLY!) and Update Directions Link
NOTE: (Cargo Cam Button removed w/Backup Cam!)
List of Changes: TSB 08-068-18 My13_My14 17.43.01.pdf
MD5: BD003E575E11988ABD4FACEDEA6AB73F
- v.17.11.07 Fw Link (2014 ONLY!) and Update Directions Link
NOTE: ONLY Version that supports Backup Cam & Cargo Cam!
List of changes: FCA tsb_08-071-17 MY13_MY14 RA4 VP4-NA v17.11.07.pdf
MD5: ADF1ADCAA4DD73CE9519C69413D414E5
I believe the firms your are looking for are in post #3 I have a 2015 (AND a Canadian Import) so I used Post #4 I used a step method going to the next version each time. I was going to stop @ 17.11 but continued to 18.x
Take it from an IT Guy you update at your own risk any time you update firmware on any computer component, it worked for me and generally following the examples given and instructions your outcome should be similar
DiscoLisS
Delaware
Hemi 6.1
RA4 does not fit on RA3. need firmware for 2014 RA3
UCONNECT_8.4A_RA3_17.43.01_MY14 this need
chrisbh17
The 17.x versions are model year specific. We don't yet have a 2014 ra3 17.x version.
Sent from my Pixel 3 XL using Tapatalk
chrisbh17
Ah, I might have one I'll check...
The idiots at UConnect had all of the earlier files taken down just before they posted 18.45.01 on the servers, so I cant grab them again.
I guess I wasnt smart enough to anticipate their idiocracy ahead of time, I had access to every single file for a long time but never bothered to download them because "who in their right mind would take them all down" ......
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
Yep...
**Still need anyone with a copy of 2014 Ra3/VP3-NA v17.11.x or v17.43.x SW files to contact me so I can share them for those that need it.**
M² Mods.
SitKneelBend
St. Louis
3.6 Pentastar
Yeah, their firmware choices are perplexing. They force hard bricks for things that would normally be soft bricks and a reflash. I also believe it is a mistake to not allow flashing of the previous firmware.
I checked, the newest RA3 files I have are 14.25_5! It's been awhile...
DiscoLisS
Delaware
Hemi 6.1
I saw Post 9.
this is NAFTA it is for canada and mexico.
I am the American version.
