INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
Ricks Ram
Manually or reverse back to drive as long stay under 10 mph I haven't install it yet I did side views same time I upgraded to power folding mirrors
Sent from my HD1925 using Tapatalk
That's pretty cool! I hadn't seen this kit before definitely something to consider.
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Is it possible to add a front camera just by using Alfa? I always thought it required third party hardware?
If you have a 2016 or newer 8.4 radio then yes you can by using the extra unused cargo cam input (manual on screen button once enabled via AlfaOBD) for the front cam input... Just need to add an RCA video Pigtail with correct radio pins into the factory radio connector.
M² Mods.
SitKneelBend
St. Louis
3.6 Pentastar
M² Mods.
Do you sell a harness?
skuppy069
canada alberta
2018 1500 cc
Whats the latest canadain uaq update available ?
I tried the us update and my radio said invalid software update .
Thanks in advance for any help .
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
I believe the official designation for the 18 Canadian radios is uCq and uCs (vs uAs and uAq for USA)...
It also looks like the current USA TSB also applies for you and the latest version would be 22.6
18 Ram UAx v22.6 TSB 08-016-19 Rev_E.pdf.
If no one has it, you can always take the cover page of the TSB, a Canadian 2018 Laramie VIN with UCQ 4c Nav, and a blank USB to a dealer and ask them to download it for you ... and hope they get you the correct one.
M² Mods.
skuppy069
canada alberta
2018 1500 cc
If no one has it, you can always take the cover page of the TSB, a 2018 Laramie VIN with UCQ 4c Nav, and a blank USB to a dealer and ask them to download it for you ... and hope they get you the correct one.
M² Mods.
Thanks Mike I will call the dealer tomorrow and ask them .
Maybe fellow Canadian owners can chime in and let me know if they have the latest .
Cheers
skuppy069
canada alberta
2018 1500 cc
I dropped of memory stick at dealer and will pick up on my Way home .
I will post this weekend if it works and if so will share it here
Mpgrimm2
Mpgrimm2
Preferred Vendor
SC
5.7L
M² Mods.
Just added the 2018 Canadian v22.6 UCQ update (4c Nav) to post 7 thanks to Skuppy069
M² Mods.
Canadian Mopar
Alberta
2017 2500 SLT
6.4L HEMI
You just tell them about the TSB and ask if they could put it on your USB drive? I see you're from Alberta as well what dealer did you get to do it?
I'm still searching for an update to my UCS that's giving me issues so might have to do that same.
skuppy069
canada alberta
2018 1500 cc
Yep I showed them the TSB and they asked for my vin .At first they wanted me to bring my truck in so they could do at no charge etc .
But I wanted the copy for the ram forum etc .
Just buy a 16GB stick and they should be able to copy it over for you .
I always got to south trail Chrysler in south CALGARY as they Always help me out .
Canadian Mopar
Alberta
2017 2500 SLT
6.4L HEMI
Tried at the dealers in Red Deer, one said they won't put the update on a stick, the other is suppose to get back to me.
Wolfpup
Shirley, NY
application version on the UAS is the fw version I’m looking for, correct? It says NN-IR-22.5.0 (then a bunch of other numbers after that). I guess I have an update to do. What happens if I don’t do the update? Everything seems to work fine so far, don’t know if I want to mess around with it yet.
SitKneelBend
St. Louis
3.6 Pentastar
If it works do not update. Unless you want to update just to see if it fails during the return period. Then you could have some piece of mind that you can safely update in the future. Latest update is 22.6...
