INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I did the updates from 18.14 > 22.6 > 28.3 without any issues. I started 39.6 and got to an issue after the initial 2-minute prep screen. Once the radio restarted to begin the update, the screen didn't come back on, even after a few minutes. I turned the truck off to see allowing the radio to sleep will fix the issue. Hopefully the radio isn't bricked...
EDIT: Letting the radio sleep worked; the radio turned back on when the truck was started. I continued the update process with 39.6 and I'll find out in 34 minutes if there were any problems with 39.6.
If 39.6 is giving you issues, you can go straight from 28.3 to 40.1 BUT let the 39.6 update fail and recover (back to a working radio) before trying to swap the files for the 40.1 update. I only included 39.6 in your upgrade path in case one of these updates specifically addressed your original issue so you could document it.
AlexSh
ny
Hello everyone. Can you help me with updating my Uconnect 8.4 Panasonic Jeep Compass 2019. It's for the Australian market i replaced I replaced my radio with this one, I'm afraid to install the wrong update. I will be very grateful for your help! Also, the radio does not allow me to change the time.
pedroklesc SVK
Slovakia
3.0 CRD
Hello, I have the same problem. I own a 2014 Jeep Grand Cherokee and I tried to update my Uconnect 8.4 and I downloaded version 17.4 from the links and everything was running without problems until I came across the message No token found for VIN (my VIN number). Please remove the USB stick to reset. After removing the usb key, it only spins, wait 2-5 minutes and then please insert update USB. Can you please help me? Thank you.
Mido
Kuwait
Dodge charger
V6
Hello
I am new here and please I need help
I have a Dodge Charger 2015 it comes with a small screen and I upgraded it to 8.4
It had an old version 15.30.2
Serial number: 68258399AD
Vp4 ROW
Can I update it to the latest version any help, please IMG_5613.jpegIMG_5609.jpegIMG_5594.jpeg
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
It’s very slow responding
Please if you know how to tell me
Well from the pictures it looks like the internal aircard may have failed (all of the Sierra values are NULL). That is what my RA4 looked like when it's GPS failed. This means that attempting to update might result in bricking the radio and it won't work anymore.
If it is running slow, can you feel if the radio is warm/hot to the touch? The best way to do this is to feel the back of the radio and the metal heat syncs. It's possible that improving the cooling of your radio will restore performance/speed.
Mido
Kuwait
Dodge charger
V6
Well from the pictures it looks like the internal aircard may have failed (all of the Sierra values are NULL). That is what my RA4 looked like when its GPS failed. This means that attempting to update might result in bricking the radio and it won't work anymore.
Thanks for your reply
When I touch it I feel it at a normal temperature all the time
it always slow responding even when I start morning and do not yet get a temperature high
I will try to check it from the back side (the metal)
So how does improving the cooling for it
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I added to computer cooling fans and replaced the factory thermal pads inside with Arctic thermal material. Here are more details...
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Hello
Vp4 ROW
@SitKneelBend
Just an FYI, the radio mentioned is an overseas 2016 Part number Charger RA4/VP4 unit, - RoW = Rest of World.
There are very few, if any -ROW sw files on this site and likely even less charger specific files (they're not the same files as 13-17 ram radios).
Also, for any updates from v15.xx.x, they need to update to v17.x.x and then to v18.x.x (if they can find the 2015/16 charger specific VP4-ROW files). CustomTronix in Holland may be able to help with Sw updates for it?
Mike G.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
@SitKneelBend
Mike G.
I actually spoke with a guy recently (no posts yet but username is @ZOLCSI68 ) that converts Uconnects for overseas customers, maybe he can help too? He sells on eBay and Facebook marketplace if you are interested @Mido
waderushton
Canada
Future 2013 to 2017 Ram RA3/VP3-NA (USA) radio Fw info....
DISCLAIMER: I am not responsible for you or what you do with your radio. It is up to you to know if these are correct for you or not. Use these files absolutely at your own risk. I am simply trying to help those that can't get a verified VIN for their 8.4 swap or want to update the firmware for some reason.
(CNET) MD5 Checker 2.31 (creator)
(GET IT! You should check your downloads against MD5’s whenever they’re posted to verify a good download.)
Latest Version: 18.45.01
** FYI. The latest v18.45.01 update for ALL 13-17 Ra3 VP3-NA and RA4 VP4-NA radios is in a separate thread at the moment & appears to require SW version 17.11.x or higher **
ROLL-UP INFO: FOTA 18.11.x & uC D/L 18.45.01 SW Update 13-17 RA3/Vp3-NA & Ra4 VP4-NA.
2013 RA3/VP3-NA (PN: )
- v17.43.01 Fw Link (removes Dual Cam Support) and Update Directions Link
List of changes: TSB 08-068-18 My13_My14 17.43.01.pdf
MD5: 61D945745FBB58249637B8A79F16E931
NOTE: The only files that should be on your Fat32 8gb+ Thumbdrive when ready will be "swdl.iso" and "swdl.upd"
2014 RA3/VP3-NA (PN: 68224531Ax)
MD5: C34A8C97BBF018ACA08E2D5DEAD9CABA
2015 RA3/VP3-NA (PN: 68238621Ax)
List of changes: TSB 08-045-18-RevA.pdf
MD5: 6EB6648BFC13C89FF576CB81E44961FB
2016 RA3/VP3-NA (PN: 6825????Ax)
- v17.43.01 Fw Link (req'd for v18.45.01) and Update Directions Link
List of changes: TSB 08-046-18 RevA MY16 RA3 RA4 17.43.01.pdf
MD5: 19412128C806BF8A2B332697A6585793
2017 RA3/VP3-NA (PN: 68270657Ax)
List of changes: TSB 08-025-18a MY17 RA3-RA4 v17.43.01.pdf
MD5: A180778F000DCB36A5D9F4C5B7F17399
NOTE: The only files that should be on your Fat32 8gb+ Thumbdrive when ready will be "swdl.upd"
I have a ra3/VP3 I believe out of a 2016 ram, what update file do I use for 68258676AF
Mpgrimm2
Mpgrimm2
SC
5.7L
Google searched this PN to find out it's a Vp3-CA (Canadian) non nav radio.
What SW version is it on now?
waderushton
Canada
Says system version 15.30.2 and then app version 15.26.1.
I have also installed this in a 2014 truck and now seeing it's the least compatible, having the volume issue along with the settings issue.
I installed the radio back in March for the themes, my truck is a 14 Sport so did come with an 8.4. Worked great until a few weeks ago I lost volume and couldn't access settings. Came back after a couple days but had now been out for 4 days.
Mpgrimm2
Mpgrimm2
SC
5.7L
You will need to update to 2016 Canadian RA3/Vp3-CA SW v17.x, then to v18.45.x
Unfortunately, I don't have the Canadian version 17.x for that year/radio.
MWGKKG
AZ
6.7L
Hello all..... THANK YOU FOR THIS THREAD.
I just finished upgrading my 2014 2500 6.7L RAM from a Harmon 8.4 to a 2018 Panasonic 8.4. Everything went very well until I installed the new Compass USB Hub. Dummy me I kept trying to get Carplay to work but I forgot that my phone was on the MagSafe wireless charger. Thanks again for all the reference material.
Jlexbak
I just picked up a 2014 Durango. it had 13.xx.xx on it, a friend at a local dealer tried updating it straight to 17.11.02. I was told the version i needed before going to the 18.45.01 i needed to have 17.43. 01! After he install what i believe was the wrong update the backup camera doesn't work. After reading 50 of this post i discovered it should have had each update in order updated. Is there anyway to go back and apply the updates that should have been done?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I believe after the 16.x.x updates going backwards is not possible BUT I also don't believe that would be necessary.
michalPOLAND
Poland
5.7HEMI
HI guys. I unfortnetly I have canadian Uconnect RA3 with soft 16.51.19. HU 68270664AE. Can I upgrade to 18.45? Im from poland and I want to have polish language, meesages.
