INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
Indaram
North Carolina
Hemi 5.7 Etorque
The ecupart.lua file does not exist in the 2013/2014 MY firmware, only the 2015 MY firmware. So the 15.25.1 prob won't have it.
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Alright folks, I still need someone to PM me a Vin for the following so I can start tweaking the first few posts:
- 2013 Ram with 8.4AN (VP4-NA)
and
- 2016 Ram with 8.4AN (VP4-NA)
PS.
If anyone has any previous fw files they want me to host, please pm me. I keep seeing people post to get previous files. Surely some of you out there have them available. Lets help some folks out.
I am in the process of downloading v14.25.5 now for 2014 VP4-NA now.
Mpgrimm2
Mpgrimm2
SC
5.7L
Updated the first few posts with the Firmware files I got a hold of.
Added MD5's also to verify downloads.
Tallsilver
RA4N update!
Many thanks to navrepair.com!!!!!! I now have working navigation along with the latest software update for my RA4N.
Anyone else that is having a problem with their RA4 upgrade, I would highly recommend navrepair.com. They were very prompt in answering all my email (questions) and kept me informed as to what was happening with my radio. Great experience.
Tallsilver
Mpgrimm2
Mpgrimm2
SC
5.7L
Tallsilver
Please provide details.
i.e.
- where did u buy the radio
- what did it cost for navrepair to fix it
- what was the issue preventing the fw update (memory fail, incompatible fw/model mis-match, etc)
- will accept future updates you do on your own
Sent from my LG G4 on Tapatalk.
Tallsilver
i.e.
Bought radio from Schram......everything worked.
after update to 15.?? nav would not activate
Cost.......depends on what's found to be problem. Mine....$100
No issue preventing firmware.....in the process of installing the latest 15 firmware the nav files were corrupted. Nav files had to be reinstalled manually. Dealer can't do this if RA4 is not in your original build code!!
Should accept future firmwares....but no guarantees!!
Mpgrimm2
Mpgrimm2
SC
5.7L
Good news. I found the serial number. I got the code. I had to use engineering mode to get into the radio to find the serial number
That is nearly the same radio part number Jared 4.7 has and he updated to the latest fw. But who knows.
2014 Ram 8.4AN
68224525AB
14.25.5>15.26.1
Zero problems since original install and recent update.
Thanks for posting pictures of that engineering screen with the part number.
To others, please share your radio year & PN:
If you press and hold both the temperature-up (red arrow) and temperature-down (blue arrow) buttons at the same time, for 5 or so seconds, you are presented with the "Engineering Menu"
Mpgrimm2
Mpgrimm2
SC
5.7L
LQK has this on ebay... Currently at $450
VP4 P/N: 68224525AH
looks like it might be a valid Ram P/N.
Jared 4.7 ....... (68224525AB),
OutlawTrucker (68224525AG), and
SitKneelBend . (68224525ZH) put the same base P/N in their trucks.
2014 Dodge Ram 1500 AM/FM Bluetooth Connect 8.4 Screen W/Nav OEM
Posted in Ebay Sale section also.
Mpgrimm2
Mpgrimm2
SC
5.7L
Alright folks, I was able to use the Quirkparts.com site with a valid 2013 VIN and came up with the following:
2013 8.4AN (RA4/VP4 NA, p/n):
Possible P/N's: (Quirkparts.com /body/Sound System using valid 8.4AN VIN)
- 5091051AD / RADIO CODE: RA4,RSD,RS7
- 5091055AD / RADIO CODE: RJ4
- 5091060AD / RADIO CODE: RA4
- 68184965AD / RADIO CODE: RA4,RSD (Appears to be a VP4-CA /Canada radio)
Not that anyone wants a 2013 VP4 radio, but its worth noting. Might be more p/n's out there. Unfortunately, none of the 2014 and 2015 Ram Vins with 8.4AN/VP4 I have pull up on quirkparts.com. I added the above to the OP.
EDIT: The above apparently verifies the following ebay item as a 2013 RAM VP4:
Dodge RAM JEEP VP4 RA4 Navigation GPS Screen Radio MP3 Player OEM 2013-2014
P/N: 5091051AC
But they want $715 ?? Really? For a 2013 VP4?
Avgas
2015 Express
3.6 Pentastar
I bought my unit from a member here.
Out of a 2014 Ram
8.4AN
P/N 68224525AE
S/V 14.25.5
hankRam2015
Out of a 2014 Ram
8.4AN
P/N 68224525AE
S/V 14.25.5
any issues with 14 radio in 15 truck? I have 15 express and considering the 14 unit.
R.L.K.
Bristol , Tn.
Hmm mmm. ...probably not , I have a 2015 RA2 IN my 2014 ( RA1 ORIGINAL truck) with no issues ..
Mpgrimm2
Mpgrimm2
SC
5.7L
Not that anyone has mentioned yet. Some people have had issues with the 2015 radios, but it may work fine for you and your 2015 truck. 2015 radio has extra features though.
hankRam2015
I purchased from car-part.com which then put me in contact with lkq near my house. It was listed for $560 I got it $530 thru some negotiating.
Mpgrimm2
Mpgrimm2
SC
5.7L
Did you successfully install your 2015 RA4 in your 2015 truck? Any issues?
hankRam2015
INFO - 2013, 2014, 2015 8.4AN FW Notes (RA4/VP4 NA)
Yes 2015 installed no issues. I have all travel link features , Yelp, etc ... No apps such as Pandora or anything...Works perfect other then not being able to connect to uconnect.
