INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
mh3c
Portland, OR
You can roll back by simply flashing the previous compatible firmware package. Emphasis on compatible.
So for a 2015 8.4 AN, the previous version is v.15.17.5?
mh3c
Portland, OR
And I only see a link to an .exe file. As a Mac user this doesnt work. I need a .zip file to unpack the ISO image.
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Yep.
Well, the only good apple, is the kind you can eat!
The .exe is a self extracting 7zip file (direct download from FCA). I'm sure that you either have an unzipping utility or that there is a Mac version of 7zip available. Just open the exe with a zip utility and copy the swdl.iso file (as-is) to a fat32 formatted 4-32gb thumbdrive with nothing else on the drive.
Beyond that, hopefully another Mac user can comment on it.
Up All Night Sleep All Day via my LG G4 on Tapatalk
ehart814
Ecodiesel
Does this help anyone?
68258671AF - 2016 I think...
Software: 15.41.4
Installed and working in a 2016 Tradesman (other than Siri will not work). I do not have access to the vin of the donor vehicle.
I would like to update the software if it's a good idea. Keep seeing mixed reviews though.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Software: 15.41.4
Only update if you have a problem.
R.L.K.
Bristol , Tn.
I agree , I have a 15 RA4 8.4NA that works perfectly , voice texting and all , I believe mine has 14.25 SW I may never update ! Mainly because of how much I use the voice texting and I wouldn't want to loose that .
Mpgrimm2
Mpgrimm2
SC
5.7L
Software: 15.41.4
With a 2016 RA4, It's s good idea to use the dealer menu (see bottom of OP) to verify the radio pn and sw version match what you posted AND especially match the pn physically on the back of the radio before you attempt to flash anything (may need to pop the radio out briefly).
There have been a few cases where it doesn't match and makes choosing the correct sw a PiTa. But it did look like you have an available update.
From my Up All Night Sleep All Day Gs7 on Tapatalk
jdomke1
Manteca, CA
Is there a method for getting map updates? I've got a 2015 and 2014 and both have the same lousy map that is so out of date. There are roads added and changed years ago and this map still has old data that shows you driving in the middle of a field and complaining that you are off track. I've searched the thread and forum and didn't see anything about this issue or how to fix it.
R.L.K.
Bristol , Tn.
Take a look at this Sir .
http://chryslergroup.navigation.com/home/en_US/ChryslerNA/USD
jdomke1
Manteca, CA
Yaa I get to purchase and update for $150. My 2015 says its up to date. These updates should be pushed automatically and for free. For those of us who upgraded from a 5.0 to an 8.4an we are even more screwed because we can't have a Uconnect account.
00R/T
CT
Chrysler is notorious for having old maps. Back around 2012 they were delivering new 200s and some other vehicles with maps that were like 5 years old. They got so many complaints that they made update discs available for free, but they were still old.
I have a 2012 300 with the previous generation 8.4 system and it wasn't until last year sometime that they even made an update disc available to purchase (they had been promoting it for years). Fortunately that system uses a Garmin nav module and some people discovered you can install maps from a portable Garmin GPS unit. So, I get new maps every 3 months for free.
R.L.K.
Bristol , Tn.
Wow I probably shouldn't complain , my maps are 14 , in my 14 Ram ,but from my 15 RA4 .
ehart814
Ecodiesel
The part number I posted is verified - I took a pic of the back of the radio. When I said "i think" what i meant was I think its a 2016 radio.
Thanks for the info. I would like to do update it if the update will make the Siri hands free work - currently Siri doesn't hear what I say.
Mpgrimm2
Mpgrimm2
SC
5.7L
Do me a favor and post that picture of the back and a picture of the Dealer Menu screen showing what pn and sw version are currently being reported by the radio to make sure they match.
You could always just try the latest sw version for your 2016 RA4 linked from the OP (v16.09.09), but it would be wise to verify the above first.
ehart814
Ecodiesel
I don't think I can get my unit to dealer mode because I am using the oemautoparts.com bezel so I don't have the buttons.
Mpgrimm2
Mpgrimm2
SC
5.7L
No you can't access dealer mode without the factory bezel (or reset the radio), so here's the deal...
Your radio pn label indicates it's a 2016 Ra4/vp4-na and your fw shows 15.41.4 (vs the 15.44.4 I pulled previously off the Ram uConnect update site w/valid vin, maybe I have a typo).
You can certainly update to the latest 16.09.09 fw but there is obviously no guarantee you will be able to roll back to 15.41.4 later.
See post 5 for 2016 fw and make sure you verify the md5 of the downloaded file to make sure you don't get a bad D/L.
jdomke1
Manteca, CA
I'd love to learn how to do this. I have a garmin handheld gps I use.
00R/T
CT
It won't work on the trucks. They use the next gen 8.4 with maps from HERE (formerly Navteq). Moving to Garmin was a huge step forward and going back to Navteq was a bad idea, IMO. We'll have to see what the new generation brings in 2017.
ehart814
Ecodiesel
I'd really like to get the siri eyes free working... Is there any reason I should be hesitant to update to the 16.09.09 FW on this radio, in my 2016 truck?
Also, does the 15.41.4 version also verify that the radio is my2016? Has anyone bricked their 2016 radio updating to the 16.09.09 in a 2016 truck???
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Did your truck come with an 8.4 from the factory? If so, go for it. If not, you can still attempt the flash but it is very important you download the correct firmware package from UConnect.
TMFMK
