MajMike
- May 28, 2018
- 106
- 76
- Location
- Panama City, FL
- 2016
- 3.0 EcoDiesel
Anyone know of a LSD or locker that fits our front axle on my 2016 1500 crewcab 4wd?
Not safe to have a LSD or locker on the front unless it's one that you only engage at low speed for traction if you need it. Look into E-lockers and arb air.
No. Quadratic actually applies braking to the slipping wheel so the wheel with better traction engages. It's still an open diff up front.Wouldn't an lsd in the front be similar to quadratrac in the grand Cherokee ?
Apologies, but I meant quadrant drive. You might want to check how it works. It has lsd in front and rear. Either way it's a moot subject for majmike, as I don't believe there is anything for our front did.
.I believe you are correct. So, good tires and maybe a selectable replacement for the rear diff. I like the Auburn ECTED, it's a LSD normally then an electric full locker. Plus a winchfor when your tires/LSD are overwhelmed.
