powderbrad
Alright, cause I just cant get enough....
Thinking some lightweight 17's with drag radial or a great street tire (275 variety either way out back), hopefully a 245 or skinny-ish out front.
2800 TC. Don't want higher, I don't tow ever really, but I still use it as a truck. just a quick street toy most times though.
I always wanted some fancy lights and gauges, so maybe a wideband AFR gauge, vac guage. meaning Ill have to drill my ARH headers for a new **** for the AFR sensor and get it welded. Can do this when I drop the piping to do TC anyways. Kinda a pain in the ass since id have to do the **** weld portion at work and get the welder to do the welding. Probably not bad though. Just get it drilled, welded and put a plug in place til I do the rest. Not really needed, but adds a sporty look to the interior.
Wondering if its worth it..I know, loaded question as its MY truck.
Thing is its a fun vehicle, and Im assuming would only be more fun with a TC and some smaller Diameter tires. no plans to buy another vehicle any time soon. Ive a company truck for work, a beater for store trips and whatnot, and my hemi for fun romps. A bike for the speed fulfillment too.
I think the truck would be a blast for a street ride.
Question:
Noticeable fun factor with a TC and tires? Drastic performance difference? I guess drastic means ANY improvement. Im SUREit would be better but worth $2000 ?? (tires, rims, TC, gauges, time, etc)
Basically the only mods over what ive got are smaller lighter tires (I also have 22 R/Ts though. lighter, and cant be much more than a 17 alum with drags. are they?)) but Im going more for the smaller tire and more improved gear reduction ratio and TC for harder launches. im sure that's where the improvements will be made.
In doing so, will it still fall on its face in 4th running through the 1/4? Im assuming so since itll shift to 4th quicker, meaning maybe the improved launching is crippled up top going to 4th negating my mods?
thanks,
MATT - looking specifically for advise since you'd be getting the order
Link to what I think are lightweight 17's. Offset and backspacing are different than stock, Id prefer a clean look, not too inward or outward at all. Price is rightr since im just running these when I wanna race around. the RT's are for show with some go
http://www.moes-performance.com/Pro_Comp_Alloy_1069_17x9_5x5_5_Polished_Aluminum_p/1069-7985.htm
Question:
thanks,
