P0740 code went way
Jaxblake
Colorado
6.4 hemi
I have a 2016 ram power wagon I got a p0740 code on a rode trip 3 months ago I clear it so I could use remote start the code came back 2 more times and I cleared the code both times I got back home and I haven’t seen the code in 3 months is it a non issue or should I get a new transmission shift solenoid and replace it
A_mod_too_far
Colorado
It probably isn't the selenoid, however that's a good cheap starting point.
Basically your torque converter is loosing rpms when it goes into full or partial lock up and if it exceeds a threshold it triggers the cel. A likely cause is worn valves in your pump which is basically rebuild territory.
My advice is to live with it if the selenoid doesnt fix the issue, just probably going to loose 1-2 mpg of fuel economy because of it, if the light doesnt annoy the hell out of you.
Do you tow alot?
jws123
nj
I would check level/get the trans fluild and filter changed if you havnt done it.
62Blazer
Midwest
How many miles on the truck? Have you ever had the trans fluid changed? Have you checked the level?
While it could just be the solenoid, just keep in mind that codes does not say "the only possible reason for this code is a bad solenoid". What it does say is there is an abnormal signal or operating condition coming from this circuit. Bad wiring, loose connections, a worn out transmission, dirty or low fluid, etc... can all be the cause.
