Tahoebronco
- Dec 16, 2018
- 117
- 82
- Location
- Dayton, NV
- 2011
- 6.7 Cummins
I wonder if the guy in the video is from California. I noticed the fuel nozzle appears to be of the "fumes recycle" kind where one has to put the nozzle quite a ways into the filler neck to trigger the sensor on the nozzle that there is a good air seal and then allowing the fuel flow into the tank. I also noticed that at first he did squeeze the handle tightly so that the fuel was at max flow.
Here is the video I was referring to in the OP.
Since PW run on Unleaded Gasoline, they have the restrictor plate at the top of the filler neck to prevent the use of Leaded Gasoline. I would say from watching his video, he will have to lift up on the back of the nozzle like he demonstrated and maybe he should try using a lower pressure setting on the auto fill lever on the fuel nozzle. Back off the pressure and raise the back of the nozzle to get better airflow allowing the air to escape the tank as it is being filled.
I'm lucky in that I have a diesel engine and my fuel neck is more open to allow the air in the tank to escape while I fuel up the truck.
