ROLL-UP INFO: FOTA 18.11.x & uC D/L 18.45.01 SW Update 13-17 RA3/Vp3-NA & Ra4 VP4-NA
MD
I used the file hosted on media fire without a problem less than 8 hrs ago. I don’t even bother with the uconnect website there’s either no update available or it’s older than what I’m already running.
bankshot
Hemi5.7
For the uconnect download, after the download go to RarLab, on the left side download rar use it to unzip the uconnect download then load the file to a USB. Follow the uconnect instructions. It it GTG
Ricks Ram
Flash- this just in from Uconnect. The 18.45 update that is download (able) from the drive.uconnect website - DOES NOT WORK. The nice lady told me that "Management says they are working on a fix but none is avail yet". She said several people called yesterday to say (like I was telling her) "the website download is doing nothing, no screen, no words, no nothing". So here's the latest. The 18.45 upgrade that is on their website -DOESN"T WORK.
I downloaded mine with no issues yesterday from the Uconnect website.
CoZo6
2021 Longhorn Limited 1500
Colorado
5.7 eTorque
Downloaded my RA4 from also from Uconnect with no install problems and functions as designed.
Rod Powell
Alabama
Hemi 5.7 L
A request - for anyone that has installed the update and has navigation (either an RA4 or an RA3 with nav activated), can you try using the nav and report back the accuracy of it?
Thanks.
Chris,
I did the MPGRIMM downloaded update, 2017 Ram 1500 Laramie 4wd SB with Ra4 Nav, and all went smoothly.
Navigation, as well as everything else so far, has worked perfectly.
Hope this helps.
Rod
Sent from my SM-N950U using Tapatalk
JPT
NY
2015 Big Horn
I may have missed this, but I got the OTA update early on, and everything worked flawlessly. BUT, I'm on 18.43.01 still, and the uconnect software update site shows (with no available firmware to download):
"YOUR VEHICLE IS UP TO DATE
There are no updates available at this time for your 2015 equipped with this system."
How are people on 18.45.X?
Specs:
Build Sheet: Uconnect 3C NAV with 8.4" Display
Window Sticker: Uconnect® 8.4AN AM/FM/SXM/HD/BT/NAV
VIN starts with 1C
Rt71668
Long Island
My 2017 Sport uconnect 8.4 just updated automatically ! Only reason I even knew was my clock was wrong and I restarted the truck and then it said your update is complete. Now says it’s version 17.51.21 I don’t seem to have any issues should I be worried ?
bankshot
Hemi5.7
Most of the updates I have seen for 2017’s have been 18.45. I would check the uconnect web site for conformation that you don’t have additional update.
Rt71668
Long Island
Thank you
Rt71668
Long Island
Most of the updates I have seen for 2017’s have been 18.45. I would check the uconnect web site for conformation that you don’t have additional update. It does say I need the 18.45 should I do it is this necessary I don’t seem to have any problems ?
Rt71668
Long Island
Most of the updates I have seen for 2017’s have been 18.45. I would check the uconnect web site for conformation that you don’t have additional update. Yeah it actually says that’s the update. I wonder why if it updated this morning it didn’t update to the newest one ? Seems to be working fine do I actually need to update again ?
762-MM
Houston, TX
6.4L
Truck: 2014 2500 Limited; Radio: RA4
Software 17.11.37 updated to 18.45.01
Updated via Uconnect download, with these observations:
  • Rec’d OTA notices on radio screen, but nothing after that.
  • Downloaded from Uconnect (software showed up a couple days ago).
  • Issue with Unzipping files - the download was 1.09GB. For some reason, the files would not extract no matter what method I tried. Downloaded again and same issue. Tried a 3rd time and the file size was then 1.27GB. File Unzip/extraction was no problem.
  • Update then failed once about halfway through head unit update. Reinserted USB and update completed successfully.
  • No issues found. For those with rear view mirror back up camera and cargo view in radio, no issues (like was observed with previous update)
chrisbh17
When it failed, did you need to start over completely or just pull and re-insert the USB?
Thanks.
mtnrider
Georgia
Thanks.
When mine failed (at about 90%) the screen prompted me to start over. It was smart enough to know it failed and initiated the sequence again. It had me remove the USB and re-insert
chrisbh17
Thanks for the info.
The package downloadable from the UConnect site has changed BUT the actual update contained within is still the same, confirmed by comparing the file hashes.
The downloadable zip now opens cleanly using Windows Compressed Folders, instead of having to decompress with a real Zip software package.
My guess is the file was always 1.2GB but some header contained in it was reporting the incorrect file size, which is why it failed when Windows itself tried to read it. Zip apps are able to cope with errors that Windows is too dumb to :)
bankshot
Hemi5.7
Rt71668, I have seen several posts that stated that there software was out of date and had to be updated to enable the new software to be installed. Someone else will chime in before long.
Cableman
Longisland
Mine said up to date also and im only on 17.11.07.
If it says up to date can i still download it from uconnect? I couldnt find any file to download...
chrisbh17
https://www.ramforum.com/posts/2121633/
Links to the update files in the above post.
UConnect wont let you download it but the files are hosted here for everyone. It *should* work OK, I have not seen anyone with issues (other than the possibility of having to flash it twice)
bankshot
Hemi5.7
Go to uconnect and enter your vin, it will tell you if you need an additional update. If so, follow the instructions.
mjf6175
NJ
cummins
Chris....if I remember correctly you too have a transplanted RA4 in your Ram? I have a 2017 Ram 2500 that had an RA3 from the factory. I installed an RA4 into it. The RA4 I obtained came out of a 2017 Ram (part# 68270661AF). It currenly has SW version 16.51.19.
My question is: DO I NEED TO UPDATE TO SW 17.43 FIRST BEFORE UPDATING TO 18.45?
I read MGrimm's post #3 on the first page and if I understand the post (and the chart in it) correctly, I do NOT need to update to 17.43 first. But I am not 100% sure since there is so much info contained in the several threads on the forum and I am looking for guidance. You and Grimm seam to be the ACE'S on this. Any input of course is welcomed!
