Speaker Wiring In Driver Side B Piller Question
load97
Home
Do the rear passenger side speaker wires pass through the drivers side B piller? I will be installing a Kicker 11HS8 Hideaway sub hopefully tomorrow. I’d like to use both left and right channels, though one channel is probably enough (left side).
misfit77
Yes.
I used the wires in the b pillar.
Only the right channel.
Sorry I can't remember the color codes.
load97
load97
Home
I found the codes online so I’m good there. Both channels are there though?
Thanks!
misfit77
No, only right side
Puba08
Long Island
I’m doing a similar install myself. I’m going to run a single 10” w/ 300w amp. To hook up the LOC, do I need to tap both rear speakers? Or can I just use the rear driver side in the B Pillar? If I need both, I’m guessing behind the radio then is easiest?
