Use LED for 9005 (high beam) replacement?
WhiteExpress
Midland, TX
I used some generic from Amazon units, they have worked great for the past week.
I did not throw any error codes etc.
I would think that even the DRL voltage would be enough to turn on the LEDs, but I am not positive of that fact.
audio1der
audio1der
Airdrie, Alberta
Ah- good catch. I should measure the voltage the DRL module puts out.
TRXHemi
Sugar Land, TX
Those are pretty sweet. Are you going to order them so we can ALL see what they look like??
audio1der
audio1der
Airdrie, Alberta
I just have to meter the pigtail later today to see what she's putting out; Greg was right that the LED will flicker or not light up at all with less than 12V- I hadn't considered that. If so, I'll just order a schwack of cheapo 9005 bulbs instead of another $50 for PIAAs for the highs which I don't use anyway.
BlownGP
Houston/Baton Rouge
That;s so **** you have DRL's..lol
but those would be great to use as DRL's, but dont except them to have any light output..
Moof
Whitehorse, YT
IIRC the DRL circuit is 1/2 the highbeam voltage (That's what Dodge used to do). DRL should be 6 volts.
audio1der
audio1der
Airdrie, Alberta
Well, to close this off, our trucks, at least in Canada, don't use the highbeams for DRLs; they use the low beams.
So, problem solved bu virtue of I can't and it doesn't matter LOL
I just to figure out how my neighbor saw my wife driving with a burnt out high beam? Why would the high beams EVER be on??
WhiteExpress
Midland, TX
Because Canada is a big dark scary place full of moosi (mooses?) and ax murders.
I'd use my high beams too!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
really? I have had a LOT of guys in Canada with the highs as the DRL....
