Water methenol injection
Goatman91
Louisiana
Is anybody running this in there engine. I'm about to buy a kit and I'm looking for 1st hand feed back.
Etroze86
Grand Forks ND
Only guys I've seen on here run it are supercharged or they just haven't said much about running it.
BlownGP
Houston/Baton Rouge
There's really no point unless your boosted.
If you boosted you can you can advance timing and/or boost. To prevent knock/detonation.
charonblk07
Calgary, Ab
F1-A forged 349ci
I'm running water **** on mine but I'm running 15psi and a built engine. If you're naturally aspirated with a stock compression then there is no benefit to water **** but if you were running a much higher compression like 13.5-14:1 then yes it can help with detonation resistance if you don't want to run race gas. The timing advance on these engines is fairly aggressive to begin with so not much more can be added before you start losing performance. A few people have tried it on the hemi cars and all have removed it for lack of results.
G
Goatman91
Louisiana
Ok glad i didnt buy it the. It was that or a set of longtubes. Thanks for the feed back yall
