DIY 5.0 to 8.4 Navigation upgrade
Status
Not open for further replies.
Ricks Ram
I'll take one even though I haven't ordered the other stuff yet. Do though the site or here?
This is a good call the harness is the only tricky part to get. The rest is all easily obtained.
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
If i can get some input on how many more people want them within the next month I may be able to double the batch from 15 to 30..
GYSOT
2014 Ram 1500
You have two screws under the pad on top of the bezel that says RAM. Remove the pad to expose the top screws. If your truck is equiped with a 120V outlet you will have another screw in your cubby hole on the right side right above the outlet. Remove them and gently pull from the top. The whole bezel will pop off.
I don't have the 120V so just the top two and then it pops out?
GYSOT
2014 Ram 1500
I'll order through the site later today. When will I receive it late October or just November some time?
CuylerTech
NH
6.7L
youll probably get it by next friday.
Tallsilver
"navigation is activating" update
Many thanks to navrepair.com!!!!!! I now have working navigation along with the latest software update for my RA4N. :grd:
Anyone else that is having a problem with their RA4 upgrade, I would highly recommend navrepair.com. They were very prompt in answering all my email (questions) and kept me informed as to what was happening with my radio. Great experience.
Tallsilver
CuylerTech
NH
6.7L
Thanks, I have the RA2 currently, do I need the purple 911 thing also?
Yes, that will eliminate the 911 Error. If you add both to the cart, it'll take $15 off the total cost.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Tallsilver
Please provide details here or over in my firmware thread.
i.e.
- where did u buy the radio
- what did it cost for navrepair to fix it
- what was the issue preventing the fw update (memory fail, incompatible fw/model mis-match, etc)
- will accept future updates you do on your own
Sent from my LG G4 on Tapatalk.
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
i.e.
Did they install the Via mobile Apps? IE Pandora, Slacker, Iheart, and Aha, also do you have the themes and Tag button still?
Tallsilver
Antenna Q
Brother has a 2016 SLT with RA1 but has the puck antenna on top. Does that mean it is a GPS antenna??
He now wants to do the upgrade. :naughty:
Tallsilver
CuylerTech
NH
6.7L
Tallsilver
The puck is for XM radio. There is no "GPS" antenna in our trucks, the RA4 simply uses the XM antenna for satellite connections.
cptwing
6.4l Hemi
No the Puck antenna does not have the Cellular antenna in it, as the sharkfin does. You do not need it just use the 911 delete plug.
GYSOT
2014 Ram 1500
Granted its a 1500, all he would need is the 911 Plug, Harness, Module, Bezel and Radio.
When I went to pay, Pay Pal had a glitch which is now fixed but when I click the link to your site I get a suspended page. What do I do?
GYSOT
2014 Ram 1500
Or you can give me your paypal address and I can just send the monies that way.
CuylerTech
NH
6.7L
Fixing it as we speak should be no more the. 15-20 minutes.
GYSOT
2014 Ram 1500
Still not working, just let me know when I can pay for it.
Status
