This is awesome, That's great that you got it working, I'll have get mine wired back up and should be good to go.Yes, it’s working now. For now, I do know that whenever a car is in the blind spot, the indicator LED illuminates on the side that the car is on. I haven’t tried yet, but, if there’s a car in your blind spot, and you hit the turn signal to change lanes, there should be an audible chime, and (possibly?) an alert on the EVIC. The cluster definitely displays if there’s an issue with the sensors and if the blind spot monitoring is turned off or on.
Give me a little bit on the part numbers for the tail lights. There’s so many depending on sensor or no sensor, and red or black.
I you want to tap the front turn signals there is a big grey plug under the fuse box that has the left and right turn wires in it, that would be a good spot to tap into, I can get the wire colors if you want.Like I post before. Is really hard take the signals from the bcm and then programming via obd. The "easy" way to do it is take the signal from the front headlamps. I see easy take the grill and headlamps out and run the wires from there than the bcm. You will need resistors. Btw. I just find the male connectors for the reverse lights in the case of halogen taillights.
Sent from my SM-J737T1 using Tapatalk
That’s awesome man .Yes, it’s working now. For now, I do know that whenever a car is in the blind spot, the indicator LED illuminates on the side that the car is on. I haven’t tried yet, but, if there’s a car in your blind spot, and you hit the turn signal to change lanes, there should be an audible chime, and (possibly?) an alert on the EVIC. The cluster definitely displays if there’s an issue with the sensors and if the blind spot monitoring is turned off or on.
Thanks. I have the way also to get the colors.I you want to tap the front turn signals there is a big grey plug under the fuse box that has the left and right turn wires in it, that would be a good spot to tap into, I can get the wire colors if you want.
No resistor. I highly doubt the door module circuits are PWM’d.Did you need a resistor for the LED or did you just connect it directly to the door module?
Do you know by chance what the ihs plugs and pins would be for a 2018 1500?Here’s a recap on all the relevant parts, since they’re spread out all over the thread:
Black tails with sensors: right- 68361722AG. Left- 68361723AG
Red tails with sensors: right- 68361720AG. Left- 68361721AG
Red tails w/o sensors: right- 68361716AD. Left- 68361717AD
Black tails w/o sensors: right- 68361718AD. Left- 68361719AD
Connector for the new tail lights (2)- https://www.mouser.com/ProductDetail/Molex/33472-1206?qs=/ha2pyFaduikiq7sntUKklFniyFE49tpyMSiTJg1I/elJCuGpayWTA==
Terminals (22)- https://www.mouser.com/ProductDetail/Molex/33012-2002-Loose-Piece?qs=sGAEpiMZZMs7eK6h2EBtKrDPZUGUvv8SUd2LU%2BdwMiY=
For those converting from factory LED tails:
Male connector that plugs into truck harness (2)- https://www.mouser.com/ProductDetail/Aptiv-formerly-Delphi/54200612?qs=sGAEpiMZZMs7eK6h2EBtKgWB1t55%2BB6K6fB%2B9lf%2B2kk=
Terminals (10)- https://www.mouser.com/ProductDetail/Aptiv-formerly-Delphi/10762775-L?qs=sGAEpiMZZMs7eK6h2EBtKhDRfMCT%2B7X7dap2iVXRST8=
For those converting from factory incandescent tails:
3-way connector that plugs into truck harness (2) (modified- note in next post)- https://www.amazon.com/TOMALL-Conne...?keywords=h13+connector&qid=1572373980&sr=8-8
2-way connector that plugs into truck harness (2)- https://www.mouser.com/ProductDetail/Molex/34675-0001?qs=/ha2pyFaduiynKIuloyba55LF6atPJdu0covSY4EBkNKK2%2BYdIlUEw==
Terminals (4)- https://www.mouser.com/ProductDetail/Molex/34080-0002-Loose-Piece?qs=sGAEpiMZZMs7eK6h2EBtKrDPZUGUvv8SfKtkLnImnL4=
CAN IHS block connectors for blind spot (different for 2018) (2)- https://www.mouser.com/ProductDetail/TE-Connectivity-AMP/5-2138650-1?qs=/ha2pyFaduhl48SvsDVuHxxswWwr8CO9ptiNqs6/s%2BqKxTyAv0wlcQ==
Terminals (8- 4 for the IHS connectors and 4 for the door module connectors LED indicators)- https://www.mouser.com/ProductDetail/TE-Connectivity/5-963715-1-Cut-Strip?qs=sGAEpiMZZMs7eK6h2EBtKqn3zbhM2DVKtrIMWXHjrgM=
Large BCM terminals for the turn signal circuits (2)- https://www.mouser.com/ProductDetail/Kostal/22140492060050-L?qs=/ha2pyFaduj8oGXoX7vSDezsCEh/TeFPHxy2z8Kh8Nv44XLlKWlO4Q==
Small BCM terminals for those with factory incandescent tails to add light fault circuits (2)- https://www.mouser.com/ProductDetail/829-13627884-L?r=829-13627884-L
LED indicators that I used- https://www.amazon.com/PLUG-N-PLAY-Instrument-Indicator-Aluminum-Speedometer/dp/B01F2GT1ME/ref=mp_s_a_1_1?keywords=3+Pack+of+PLUG-N-PLAY+Instrument+Cluster+LED+Indicator+Light+Dash+Bulbs.+Aluminum+Pilot+Lights.+Color+Acrylic+Lens.+Flush+Panel+Mount+5/16"+8mm+12V+for+Speedometer+Odometer+(Black+Bezel,+Amber+LED)&qid=1572375248&sr=8-1
3/8” split wire loom
Tessa tape
~100’ 18-20awg wire. Good source- https://4rcustomswire.com/
~50’ twisted pair wire. I used- https://www.amazon.com/Jameco-Valuepro-Stranded-Twisted-Applications/dp/B00B887D80/ref=mp_s_a_1_1?keywords=Jameco+Valuepro+Stranded+Twisted+Pair+Cable,+24+AWG,+100'+Size,+Green/White,+Ideal+for+Voice+and+Data+Applications+-+224GW/C-R&qid=1572375357&sr=8-1
That’s where I got my new left tail from. They’re definitely new takeoffs, so they must come from flatbed conversions. Nice guy I talked to, I had him get the part in his hand and he called me back with it, and text pictures of it while we were on the phone.This is great. Just got done wiring my tails today. Now I plan on doing the blind spot. I plan on buying some 2019 power fold tow mirrors with blindspot and make it as oem as possible.
On a side note, for those interested in a source for tail lights I got new take offs set from car-parts.com for 720 shipped with blind spot. The retailer was Veldman's auto parts. Here is a link below.
http://car-part.com/cgi-bin/search.cgi?userSearch=exact&userPID=1000&userLocation=USA&userIMS=&userInterchange=[|{r&userSide=&userDate=2019&userDate2=2019&dbModel=22.31&userModel=Dodge Truck-2500 Series (1994 Up)&dbPart=166.1&userPart=Tail Light&sessionID=13000000027012563&userPreference=zip&userZip=91355&userLat=34.4173000&userLong=-118.5733000&userUID=0&userBroker=&iKey=&userPage=3
You can find them cheaper, I got my pair for $500, including the truck side connector and harness. But if this tail light swap catches on the price may go up even more once sellers see a demand.Man those things are expensive.
This mod might be too rich for my blood![]()
