18ram2500
It’ll be easiest if you go on here- http://connectors.dcctools.com/home.htm#photo And write down the functions and connector/pin locations for both a 2019 2500 and your 2018. Then, start repinning the connectors.
Couple things to note:
If you keep your door modules, you will only gain the blind spot lamp function from the new mirrors. Your current door modules don’t have outputs for the convex mirror adjustment, turn signals as park lamps, or the trailer spotter lamps. EVEN IF you got the 2019 2500 door modules that support all those features, there’s no way to enable them (currently). They would all have to be added under the doors configuration list in AlfaOBD. If it was me, I’d just get the 2019 door modules, see if they work, and hope there’s a way to add those features with AlfaOBD in the future.
As far as the 360 view camera goes, I doubt that one can work. That means you also need the forward camera and the central vision processing module. Then, if you can even get the CVP module online with AlfaOBD, you would need the 12” or 8.4” radio from a 2019 to display it, and we already know the 8.4 radio from a 2019 won’t work in the pre-2019s.
Thanks. I really appreciate the input. The man reason I got the top of the line mirror was for the power fold option. The rest would be a plus if i could get them to work.
