AlfaOBD
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
You know, my dealer is not what I would call "the best". Quite frankly their Sales dept is pretty slimy and most of the Service dept is half-assed, but I've come to the conclusion that the Parts dept is Top Notch. I had no trouble getting my codes (RF, Key & Radio Security), I was not charged for them and they've been more than willing to lookup up parts that don't technically fit my truck.
-K
My local dealer's service department is not very good either, like a 1970's set-up. They are so bad that they can't even register my odometer reading or address correctly. Told me my girlfriend's Jeep needed an AC condenser for $1100 and all it needed was a 1/2 can of 134 in my driveway to fix that over 2 years ago. One day the service writer counter will be in the service bays and the next day they're all at desks in the parts department showroom / customer waiting area (with the customer waiting chairs removed).
But just like kad wrote, the parts department at my dealer is excellent and never are anything less than totally helpful with free pins, codes and part #'s
chrisbh17
The dealer I bought my truck from is newer, or at least they have remodeled into the "new look" showroom, etc. The parts department is right off the showroom and is kinda like a gift shop/parts department (you walk through clothing and accessory displays to get to the parts counter). I would expect there I would be charged for my PIN number.
A dealer that is more local to me is like the old 70s/80s setup....the showroom is OK, but parts and service look more like a service station garage setup. It is there where I obtained my PIN for free.
Maybe its just the culture brought about by the overall modernness of said dealer. Fancy look? We get to charge you for everything. Mom and pop? yeah we'll help out the average guy who was nice and just asked a simple question.
Canada
change idle hours does not work i tried to lower from 480 to 479 and it keeps saying select an option
1500ram12
5.9L Cummins
Alexey is aware of this. It will be fixed in the next update
Canada
called one dealer he said yes come on down ill give you the pin. so i went today they said nope not a chance. called the dealer where i bought it talked to the parts manager she said idk why they wont come see me ill give it to you. she said the code exp in 12 hours is this true ?
1500ram12
5.9L Cummins
No. The 4 digit pin is good for ever. I believe There is a rolling code given to 3rd party businesses for keys
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
That is correct, the rolling pin expires in 12 hours
What everyone should be asking for is this printed sheet and none of this information ever expires:
DC DealerCONNECT
Key Code Inquiry Results
VIN: 3C6JR6AG1JG#######
Ignition: M14##
PIN: 36##
The pin # is for the RF hub and the ignition # is the key code to cut a key with no duplicate available. All of the filled in numbers and letters above are just for example (except that the ignition will start with the letter M).
idtanker
Boise, Idaho
Hello all,
Is anyone using fog lights as your drl's? If so, could anyone tell me if they drop out with independently with blinkers or remain on?
Thanks in advance.
Sent from my SAMSUNG-SM-G891A using Tapatalk
I have fogs as my DRLs as well, and they remain on constantly. I have had this setup for about a month or so, and have had no problems as yet,.
WVRam68
WV
Thank you all for the help.
Working out how I want to make drl's work like Arth has with his new morimoto xb lights, except mine are quads and not projectors. Was going to use fog harness I got from M2mods, but if it doesn't drop on blinker, kind of same thing morimoto is doing with fuse tap and making them burn with ignition or whatever. So have a new plan, will see how it works out.
Thanks again
fearroyo
Tampa, FL
EcoDiesel
Chrysler Pin Pull app worked great, $15 to get the code. If you can't find a dealer doing it for free.
2019Classic
Factory. And I have searched and searched and have yet to find someone that was able to change the trailer name with the 8.4 Uconnect? Everyone complains about it because it says you can do it in the manual?
Have you come across a fix for this issue?
I just installed the OEM brake controller. I can see the controller on EVIC, but nothing on the 8.4 screen. I've enabled and double checked that the 3 trailer CSM's are set to "YES".
Not sure how to get these menu items to show up.
Ricks Ram
Are you looking on the settings menu on the radio? Sorry if you have checked there just wanted to make sure. If you have already checked I reccomend letting the truck sleep for at least a day if you haven't already. The UAS and UAQ radios take a long time to show the codes when they are added. 0cea31f5ae8bd822e8fcc295029e3f9f.jpg
WVRam68
WV
DRLs: (Daytime Running Lights)
CBC Features: DRL Configuration
Select “Optional DRL”
CBC Features: DRL Lamp location (several to choose from, high beam, low beam, fog lamp, dedicated
and SRT Light Bar) Known working high beam, low beam, turn signal and fog lamp.
CBC Features: DRL Dropout Enabled
Select “yes”
ECU 3: DRL Customer Setting Enable/Disable
Select “yes”
Customer Service Menus: Daytime Running Lights CSM
Select “yes”
Last step
mtnrider
Georgia
I just set the "Trailer Name CSM" to Yes and it has been working fine. Not sure why you are not seeing it?
Canada
Select “yes”
Select “yes”
Select “yes”
Last step
thank you worked
Orca
