- Joined
- Aug 29, 2022
- Posts
- 3,239
- Reaction score
- 7,969
- Location
- Ontario Canada
- Ram Year
- 2023 Warlock
- Engine
- 5.7
Here's the other consideration....Good idea on the compression test.
I am due for an 8 speed service, and I want a PPE pan and @caulk04's bypass as well. That will have to be after.
I have no misfire codes atm, and I might not be able to see any noticeable difference in valve travel if it is early enough.
If valve travel appears normal, then it will have to be torn down to inspect the lifters/cam, especially if no metal is on the oil control valve.
Oil strategy is fine, but if there is a problem brewing, I don't want to run it to the point of misfire, then bearing damage chances increase.
Yes, to all parts you reference, plus new OCV and MDS solenoids, IMO.
The cam and crank bearings are concerning if needing changed.
Thank you all so much for your input. Keep the suggestions coming.
For the $3 to $4 thousand for all the parts & consumables (or more), given the mileage and the input regarding bearings, etc., perhaps you go for a new engine altogether and call it done?
You'd then be starting fresh and have a new engine warranty as well.
You could then maybe donate the old engine to a local school for learning purposes?
