Do I have a lifter going out? YES, I DO!!!!!!
EdGs
EdGs
FL
Finished lapping my valves, removed the phaser, and pulled the driver side oil galley pipe plug there was still some oil toward the rear. I did not see anything else in there, buildup, etc.
There was some sort of sealant on the plug, which I likely don't have. I believe its a tapered pipe plug.
Can I use some blue loctite, or do I need to go buy something else.
I'm gonna leave the passenger side galley plug alone, being that driver side was clear as far as I could tell.
Hunt up some pipe dope/sealant with PTFE Ed,as it's a NPT plug.
Odds are it wouldn't leak oil past the threads with blue loctite,but if it did,it really suck having to pull it down again just to reseal a leaking pipe plug ;)
EdGs
EdGs
FL
I grabbed this, got home and realized it's not ptfe, but it's for pipe threads.
Says seals threaded metal fittings on hydrauluc, pneumatic, fuel, and cooling systems.
Is this ok? Or, am I going back to the parts store?
EdGs
EdGs
FL
I left it alone for now.
I bought a Motorad 192° thermostat. I tested it on the stove and it started opening around 196°, was fully open around 205°, as near as my old eyes can tell.
I removed it from the heat, and it was nearly closed at 192°. So, it looks like it is working ok, at least for now.
It'll probably work perfectly fine Ed.I use either ARP thread sealant or Loctite 592 thread sealant,neither one has ever let me down,but the Permatex brand is probably just as good.
EdGs
EdGs
FL
Yea, I went on the Permatex website and looked at that stuff. Website says, "contains PTFE". I don't see it anywhere on the package, though.
View attachment 572841View attachment 572842
It'll be perfectly fine Ed,i wouldn't worry about it.It's probably virtually identical to either the Loctite or ARP versions of thread sealant.
EdGs
EdGs
FL
I might just as well pull the passenger side plug now. Ed luck says if I don't, there'll be an issue.....lol.
Seriously, I can now put a dab on the block drains while I'm at it.
Thanks for putting up with me second-guesssing myself. I am decently mechanically inclined, but this is only the 2nd engine I've ever torn into (by myself).
EdGs
EdGs
FL
Went ahead and pulled the passener side oil galley plug. Looked same as driver side, some oil still in rear part of galley. Cleaned off the oil galley plugs, added thread sealer, torqued to 20 ft-lbs.
Installed the thrust plate, cam phaser + new bolt w/loctite, torqued to 90 ft-lbs. (My God, did it seem like it was never gonna click my FIL's Snap-on 1/2" drive 50-250 lb torque wrench)
Hope timing is set right:
Installed guide and tensioner, 8 ft-lbs this time....lol.
Gonna give the chain a coating of assembly lube, then install the oil pump.
Yardbird
Western NC
It's a lot of money we sometimes don'r have to do the job right....BUT....If we skipped a step we knew deep down we should have done, from then on, every noise or hiccup, you would be wondering and worrying if that's the part causing that you should have replaced.
Been there, done that.....
My dad used to shortcut repairs on his cars sometimes. I would try to talk him into doing it right, which occasionally worked, especially if I finished the job.
He would get ticked when I would pull out the old line..."If you don't have the time to do it right this time, when will you ever have the time to do it again when it breaks".
Yardbird
Western NC
I've been out checking the brake caliper slide pins for proper lube. I put new slotted rotors on front a while back, but couldn't remember if I checked the pins or not.
Whether I did or not, the front drivers side had enough lube to last 20 years, so I didn't bother to check the rest, as all the boots looked good.
That, and the humidity feels like it's 125%. I didn't do much and look like I fell in the river.
EdGs
EdGs
FL
I heard that. Temps here weren't too bad. At least it wasn't blistering hot like a couple weeks ago.
EdGs
EdGs
FL
I tried to convince myself that it would be ok to use the old valves and rocker arms, even when various members here suggested replacing them, but deep down I knew it was best.
I have to update my parts list, I will probably just repost it with additions. I've spent just over 5K in parts, tax, and shipping over 5 or 6 orders, could've saved a bit there, and probably didn't have to replace all I've bought, but 200k is ALOT of miles with no issues. Also dropped another $700 ish for cheap oil and filters, RedLine oil and a premium filter, coolant, some tools and various supplies, and one of @caulk04's 8HP70 thermostat bypasses, etc.
All parts OE except, FelPro intake, valve cover, exhaust manifold gaskets, and injector o-rings.
The only parts I won't have changed are cam, crank, rod bearings, pistons, rings, and rear main seal.
Fingers crossed I get her put together correctly and she runs....lol
EdGs
EdGs
FL
Here's the list of parts I have purchased for my truck (so far......lol).
2015 RAM 1500 SLT QC 5.7L 2WD 8SPD
201,192 miles
2x 5038785AD MDS lifters, front set w/yoke
2x 5038786AD MDS lifters, rear set w/yoke
1x 53022263AF MDS camshaft
4x 53022298AA MDS solenoid
1x 6102430AA camshaft bolt
1x 53022243AF camshaft phaser
1x 53022338AB oil control valve
1x 53022317AC crankshaft sprocket
1x 6510763AA crankshaft bolt
1x 53022316AC timing chain
1x 53022115AH timing chain tensioner
1x 4893429AA timing chain guide
1x 68195993AD Hellcat oil pump
16x 68080909AB valve springs
8x 53022087AC Intake valve
8x 53022088AD Exhaust valve
16x 53022090AB valve stem seal
2x 53021552AB Intake rocker assy
2x 53021553AB Exhaust rocker assy
8x 05045515AA intake pushrods
8x 05045516AA exhaust pushrods
20x 6510280AA head bolts, long
10x 6506334AA head bolts, short
1x 53022306AC head gasket, right
1x 53022307AC head gasket, left
1x 53021568AE oil pan gasket
1x 68391488AB water pump gasket
1x 53021521AD timing cover gasket
1x 53021585AD crankshaft seal
1x 53020861AA oil pickup tube o-ring
1x 53021144AA oil dipstick tube o-ring
1x 55056906AH heater hoses (no 3way)
4x Fel-Pro E70599 fuel injector o-rings 4 pcs.
1x Fel-Pro MS97083 exhaust manifold gaskets
1x Fel-Pro VS50625R1 valve cover gasket set
1x Fel-Pro MS97089 intake manifold gaskets
16x NGK 92145 Spark plug
1x Motorad 416192 thermostat 192°
3x SuperTech 5w-30 conventional oil 5 qts.
2x Fram TG2 oil filter
2x RedLine 5w-30 oil 4 qts.
1x Fram FE2 oil filter
2x 68163848AB OAT coolant concentrate 1 gallon
2x distilled water 1 gallon
