Finally installed tow hooks on my sport, pics.
16WhiteQC
Hudson valley, NY
***EDIT***
See post #13, page 2 for added cut out specs and bracket details.
First and foremost, thank you to those that have already done this mod and shared the details/dimensions for the custom brackets, they worked perfectly!
I got the hooks for free from a friend, and used the dimensions posted on the forum to have brackets made and powder coated at work.
Took my sweet ass time test fitting, measuring and cutting out the lower bumper insert for a tight, clean fit.
Overall I am very happy how it came out.
My ARB recovery strap slides right on with out touching any paint. Going to pick up a Gator soft shackle to be safe.
20200425_120046.jpg 20200425_135507.jpg 20200425_180823.jpg 20200428_140530.jpg 20200428_140508.jpg
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
View attachment 204866 View attachment 204867 View attachment 204868 View attachment 204872 View attachment 204873
How the heck did you get the hooks through? Those are the smallest, cleanest holes I've seen for this mod.
korby05
Delta, PA
5.9 Magnum
Those look awesome
Sent from my SM-G973U using Tapatalk
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
At least you put em on correctly but to each is own, I still get a chuckle when people put them on backwards with the open ends of the hooks facing each other. lol.
16WhiteQC
16WhiteQC
Hudson valley, NY
With how I oriented them I was able to "thread them into the hole", basically put the hooks in sideway and rotated through cut outs and then bolted them in (if that makes sence)
I know a lot of people think they look better facing in because they are centered in the end opening more...but I wanted function.
corneileous
Podunkyville, OK
See, I don’t even see how they look better that way, tho. I think they look better, even if you don’t use them, being put on the way they’re supposed to be on. That would be like putting your steering wheel on upside down....lol.
After I got my truck back from the body shop when I smacked a deer no more than two months after owning my brand new pick up, I ended up having to take my new tow hooks off and turning them around because the knuckleheads at the body shop put them on backwards.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Ha! Very clean!
Do you happen to still have the template you used to cut the holes? I'd pay you to ship them or even better if you could post something that's printable?
R.L.K.
Bristol , Tn.
Very nice cutouts
16WhiteQC
16WhiteQC
Hudson valley, NY
Ha! Very clean!
I think. still have the cardboard, but it did not transfer 100% to the insert.
I can try and get some measurements from my actual insert, they should work.
(I did have to add a 1/8" x 1" flat stock spacer to move the hooks down a bit due to the feature in the insert)
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
That would be great, I'm sure others would like it too so just post it here!
mike19950
Delaware
Looks great! I'd like the measurements of the openings too. Not happy with how mine turned out.
16WhiteQC
16WhiteQC
Hudson valley, NY
Sorry for the delay,
Here are the cut out specs, and the bracket I used (brackets are not my design, I take no credit. It was posted on here).
I used the "rib" feature as a ref. point to make things easy (that is what the masking tape showing). I also used the "rib" as the top line for the cut out.
Let me know if anyone needs more info.
13ram1500crew
Ontario
HEMI
***EDIT***
Im confused. Are these F150 parts? or did you put them on to help your friends with F150's?
They look good though, good job.
Adamcr68
Lorton VA
Hemifever 5.7
***EDIT***
Excellent work! Looks like they were factory installed
Georgiasport
Douglasville, Georgia
Just about to test fit the relocation brackets I made today from the above drawings. I used 3"x3"x3/16" angle iron. Wasn't as bad to make as I thought it would be. I did leave extra material on the inside of the hook area to hopefully attach brackets for a light bar.
TMFMK
