INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
jdomke1
Manteca, CA
Not sure I like how Siri works with this latest update. Seems slow to respond and full of errors. Anyone else liking it?
ehart814
Ecodiesel
Did your truck come with an 8.4 from the factory? If so, go for it. If not, you can still attempt the flash but it is very important you download the correct firmware package from UConnect.
No, my truck came with RA1.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Did you install an 8.4 radio (RA3 or RA4)? If so, do you have the VIN of the truck your 8.4 came out of?
Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
No he doesn't have a VIN, but the Pn he posted indicates it is a 2016 Ra4.
Not sure where he got it but he is also using the OEMAutoPartsCo bezel (not a full conversion).
See prior posts
http://www.ramforum.com/showthread.php?p=1358737
http://www.ramforum.com/showthread.php?p=1365716
From my Up All Night Sleep All Day Gs7 on Tapatalk
ehart814
Ecodiesel
See prior posts
INFO - 2013, 2014, 2015 8.4AN FW Notes (RA4/VP4 NA) - Page 44 - DODGE RAM FORUM - Dodge Truck Forums
I purchased the unit on ebay. It included the harness, and bezel. I believe the guy I bought it from bought it all together as a kit from oemautoparts.com
Unfortunately, he was not able to provide the vin number for the donor truck.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Well you may be able to contact them for the correct firmware package. You can attempt a download and install yourself based on the info you have, but if you flash the wrong firmware you may have issues or a brick.
Mpgrimm2
Mpgrimm2
SC
5.7L
Your radio pn label indicates it's a 2016 Ra4/vp4-na and your fw shows 15.41.4 (vs the 15.44.4 I pulled previously off the Ram uConnect update site w/valid vin, maybe I have a typo).
You can certainly update to the latest 16.09.09 fw but there is obviously no guarantee you will be able to roll back to 15.41.4 later.
See post 5 for 2016 fw and make sure you verify the md5 of the downloaded file to make sure you don't get a bad D/L.
If you want an update you are left with two options ...
Use the 2016 FW files in post 5 or contact OEMAutoPartsCo (NavRepair).
ehart814
Ecodiesel
I read somewhere that there is a new update - possibly having something to do with Apple iOS 10
Can anyone confirm this?
00R/T
CT
I don't believe that's the case. 16.33.29 was released last month for 2016 models. I'm not sure if there was a similar update for earlier years. I never bothered to install it because there was nothing exciting in the release notes. I'm on my phone now so it's a pain to link, but if you do a search for 08-057-16_REV.A you can see what was fixed.
Mpgrimm2
Mpgrimm2
SC
5.7L
Updated post 5 with the 2016 RA4 v16.33.29 fw link, TSB Change notes, and update directions.
Note: Took a look online at a few 2017 Rams with RA4's and they appear to be the same radios/architecture. Looks like people will be able to convert ra1/ra2 radios to the 8.4's for another year.
Here's the TSB 08-57-16 Rev A notes:
NOTE: This bulletin applies to vehicles within the following markets/countries:
NAFTA.
NOTE: This bulletin applies to vehicles built on or before April 02, 2016 (MDH
0402XX) equipped with Uconnect 8.4 (Sales Code RA3) or Uconnect 8.4AN
(Sales Code RA4).
SYMPTOM/CONDITION:
Customers may experience one or more of the following:
· **Satellite radio reception improvements.**
· Navigation failed message is displayed.
· Clock not automatically updating to local time.
· Poor or no connection to cellular network. (U.S. Market Only)
· HVAC temperature out of sync with radio display (KL vehicles).
· Display goes blank/black.
· Radio locks up.
· Some Uconnect App remote commands do not execute with the vehicle. (U.S.
Market Only)
00R/T
CT
Correct. We won't be seeing the new radios this year. A mid-year update would be amazing because it would mean it has to be compatible with everything the existing one is. But, I'm not holding my breath.
The trucks are getting redesigned for 2018, so I expect that's when we'll see them.
R.L.K.
Bristol , Tn.
Awesome!
R.L.K.
Bristol , Tn.
This means another year of folks in the future helping us and we being able to help them mod and figure out compatability of or trucks evic and radios !
ehart814
Ecodiesel
I extracted the update file to a thumb drive. Used the md5 checker and codes match (whatever that means)
I emptied the thumb drive before extracting to it, after extraction it shows 2 files:
swdl.iso
swdl.upd
is this ok? The posts in this thread say the only file should be swdl.iso
Mpgrimm2
Mpgrimm2
SC
5.7L
swdl.iso
swdl.upd
Yes, per the update directions for the last 2016 fw (post 5), there will be two files.
(The prior releases only had one file)
I will update post 5 later.
Sent from my SM-G930P using Tapatalk
ehart814
Ecodiesel
Thank you
Mpgrimm2
Mpgrimm2
SC
5.7L
Thank you
Your welcome. You should download the fw directions for that file to make sure you go through it exactly as described.
DrkRam
Maine
2017 crew cab Night Edition
harness
the harness connection web site seems to be shut down , where else can i get a harness for this conversion? thanks
Mpgrimm2
Mpgrimm2
SC
5.7L
Pm'd
Ricks Ram
They won't let us type in the website but there is a place you can get them if you scroll through the posts you should be able to find him. I tried to type his website and it was immediately deleted.
TMFMK
