Mufflex 18" on Order
quietpeen
2021 TRX
Hellcat
Should I try and find better clamps before I do my install? who makes the best clamps?
the rear clamps are welded onto the hanger so i wouldn't look to replace those.
arcstarter
Wainwright, AB
2011 1500 Laramie Crew 4x4
ahh ok I do have have some stainless welding rods so I could cut them off and put new clamps if needed I guess, The front clamp is 3" ID-OD?
WhiteExpress
WhiteExpress
Midland, TX
Pretty much any auto parts store has stainless band clamps.
You need a 3" variant. I have no issues with my back clamps, only my front seemed cheesey. I'm just going to have it welded in here in a few weeks.
LB3711
Trumbull, CT
3.6L V6
A band clamp like I posted you should be ok. Just make sure everything is lined up and the pipes are in as far as they go. Mine hasn't moved since.
Sent from my AT&T iPhone 4.
WhiteExpress
WhiteExpress
Midland, TX
This shows well the crappy clamping job the Mufflex front clamp does.
arcstarter
Wainwright, AB
that's a joke, would it help to fill it with some high temp silicone?
LB3711
Trumbull, CT
3.6L V6
yup wait till the muffler slides off. lol
quietpeen
2021 TRX
Hellcat
hmmm i will have to crawl under my truck....i thought the pipe was a tighter fit than that. I didn't think there was enough play in the hangers for the muffler to slide off
LB3711
Trumbull, CT
3.6L V6
You can tighten the clamp super tight and still no go.
quietpeen
2021 TRX
Hellcat
how long would it stay on before it slipped off?
arcstarter
Wainwright, AB
I was reading on another car forum that if you use high temp RTV on the pipe before you slip it on and clamp it should eliminate leaks and still be easy to take apart if needed
quietpeen
2021 TRX
Hellcat
What did it run you?
Mine *** just over 250 shipped...go to mufflex. Go here and you can see what shipping is after you put it in the shopping cart
arcstarter
Wainwright, AB
nope, Mufflex charged me 80 to ship... Usually if you ship USPS you don't have any customs or brokerage fees
quietpeen
2021 TRX
Hellcat
For me not long at all. Within a week or so I got the better clamp
Hmmm mine has been on for two weeks now I think
Neuropathysux
