Hello my software version for 2015 Ram Laramie is 14.29.9 can i download the last version from this site? Thank you in advance
* Dealer Mode (Use this to identify your Radio's P/N and S/N !)
.. Hold Hot+Cold+Front defrost buttons for 5 -10 seconds
Guys I have the files for 18.45.01 for GC2015. if you have 16.16.13 which recommends going to a dealer. It will need to upgrade to 17.43.01 1st then upgrade to 18.45. Just did my upgrade no issues, just make sure you strictly follow final upgrade steps 11 & 12 and then turn ignition to run and leave alone for 5-10 min to allow apps to properly load.Starting a new thread that I can update/edit to help out.
DISCLAIMER: I am not a coder, developer, software guru, electrical engineer, etc. but I did sleep at a Holiday Inn Express once!
I am not responsible for you or what you do with your radio. I am simply trying to help those that can't get a verified VIN for their 8.4AN upgrade/swap/update.
Big thanks to @chrisbh17 for helping behind the scenes get additional info !
See TSB 08-089-19 LINKED BELOW
TSB 08-89-19 FOTA RAx v18.45.01.pdf
Here's the SW update instructions for when the files are available....
RRT-7153 RAx v18.45.01 Update Instructions.pdf
** Links will be in post 3 once I have them **
Need everyone to keep an eye out for an official v18.11.x or v18.43.x download file if it becomes available for each Ra4 VP4-NA year from 13-17 (& Ra3 Vp3-NA).
[C]** For those that get the OTA update, please last is know your truck/radio year, model, & final SW version from the settings menu or dealer menu **
(ie 17 Ra4 VP4-NA v18.45.01 or 15 RA3 Vp3-NA v18.11.07, etc) [/C]
There are a lot of folks out there with 8.4 upgrades and factory radios out of warranty this will affect on Nov 3.
See the TSB above and the Sierra Wireless technical document references by Chrisbh17 below.
List of current RAx Sw versions & what they will be updated to:
May try again to see about getting the other threads merged here.
Fried Dumpling's: uConnect Update ? thread.
Note: once all this is available, I will add what I can to...
INFO - 2013-2017 8.4AN FW Notes (RA4/VP4 NA).
M² Mods.
Just curious, I had posted the Canadian updates 17.11.07 and 18.45.01 that i used on my previous truck. I know that a few of the guys have used it. I sold that truck last summer and while cleaning up the computer, i came across those files and was debating deleting them. Another member had recently said he was unable to download the shared files. Should i re upload those before i delete them, or are there a couple trusted source for canadian updates that everyone has access to?No need to offer up files since they are already posted/linked for the Ram trucks that need them ...
& No offense to you Hawk, but with recent hacked/spam accounts that keep trying to get on the site, NO ONE should be downloading ANY sw from ANY recently created user accounts and should be skeptical of any posts/for sale threads etc that seem too good to be true.
M² Mods.
(via Tapatalk App)
Yep, you're links were the ones everyone was using. I'm out of space on my free cloud account.Just curious, I had posted the Canadian updates 17.11.07 and 18.45.01 that i used on my previous truck. I know that a few of the guys have used it. I sold that truck last summer and while cleaning up the computer, i came across those files and was debating deleting them. Another member had recently said he was unable to download the shared files. Should i re upload those before i delete them, or are there a couple trusted source for canadian updates that everyone has access to?
I know that i messed up downloading a file to Thumb Drive
2016 Ram 1500 w/ 8.4AN radio
Current version is 17.11.07
I received a notice to upgrade to 18.45.01
The dealership said that they were going to do a radio update & they claim that they did, BUT my radio still reads 17.11.07
So i went to the Uconnect website & downloaded the update to My Download File, it was a ZIP file & i extracted it to another file & checked it out, the 5 files were there & i loaded them onto a Thumb drive. I checked the Thumb drive & the 5 files were on there.
I stuck the thumb drive into the correct port.
The radio is refusing them
I then drove to the dealership to insure that the USB ports were working, they checked them & showed me they worked great, 1 seems to be a charging port & the other is for downloading & uploading files
I bought a 32 gig thumb drive & it had 2 files on it, 1 of them was called VAULT & that is where i d/l the files to
I'm in the same boat with a Canadian 2014. I have the 2015 17.11.07 software update but some have said that it has to be 2014 software so I have not tried to load it. I was going to try and ask my local dealer if they can load it onto a thumb drive. If you find a solution before me please post it here.
Does it specify "Canadian" anyplace?
