What Octane Is Everyone Running
Mvp_Me
West Palm Beach,FL
2019 Laramie 1500
5.7L V8
I run 89 because the manual recommended it but if you’re just casually running around town 87 is fine, if you’re a spirited driver you will notice more responsiveness and better performance overall. You won’t feel the extra power on the “butt dyno” but the engine will run more efficiently.
TigreST
Canada
Four things you don't talk about on the internet: Religion, Politics, Oil and Octane. Ha ha. I run the factory recommended 89 in my 2018 RAM. As I'm employed in the oil industry I basically purchase fuel at the outlets that sell the gasoline that I make at work...paying my own paycheck if you will. There is also some savings of pennys per litre to be had and a points system, a linked bank card savings sytem etc.
Fresh fuel: Visit high volume fuel dealers and you will have a better chance of getting fresh fuel. The storage tank volumes are turned over on a more regular basis. That said , I have no idea how you can tell which is a high volume vendor or not in all truth. It might also be true that if it's a high volume vendor your gonna wait in line for a pump maybe?
Brand loyalty: It is fine (IMHO) to have brand loyalty if for no other reason then to take advantage of the different points and penny saving plans that each may offer. Just don't think for New Your minute that you are actually buying gasoline that your fav brand produces on any given day. Fuel producers and vendors are only legally required to sell you fuel at the advertised octane rating posted on the pump. Fuel producers routinely buy and sell fuel volumes from each other in order to maintain contracted supply volumes to there retail outlets. Refiners routinely shut down refinery operations to perform major unit maintenance outages (we call them "Turn Arounds") and this typically might result in a fuel volume short fall for that refiners retail outlets. That refiner purchases fuel from other produces to keep the retailers tanks full. You may never notice this when you purchase fuel from your fav vendor.
Octane -v- more refined (better) fuel: Remember this, a refiner wishes to spend no more time, energy or money producing your fuel then they have to, while still meeting the specs of the fuel. Yes there are standards of production quality as relates to fuel specifications but this does not mean that by virtue of the octane rating you are getting a "better, cleaner, more refined fuel. You are simply buying a fuel that has the advertised octane rating.
Seasonal Blending: We have all heard the term but many do not (perhaps) understand what it means. The fuels component parts are blended to give the best performance dependent on the seasonal time of year which relates directly to the predicted/historical ambient temperature conditions. As the ambient temp changes so does your fuel blend. You'll have noticed in the summer that when you spill fuel while refilling the lawnmower on a 85F day that within short order of having hit the pavement the gasoline readily vaporizes and disappears. If you took that same "summer blend" fuel and spill it in the same spot in Dec, Jan, Feb (for those of us in Northern climates) you will not see the same rate of vaporization...it will take a degree longer to vaporize. In summer months due to the available heat provide by mother nature fuels vaporise at an increased rates. The fuel blend changes (gets heavier,..less light ends) to attempt to keep the rate of vaporization to a semi constant level. A measure of this vaporization testing is called RVP (Reid Vapor Pressure) This helps your intake system perform to it's best and reduces the possibility of "carb or intake icing"( haven't heard of an instance of that for decades). Leading into the winter months the fuel is blended to increase the light end components which help reduce engine flooding conditions and help with better engine start performance during lower ambient temperatures. Remember that it's not the fuel liquid that burns, it's the fuel vapor (mixed with air) that burns in your engine. If the fuel does not vaporize it can not ignite correctly.
Did I mention I use 89 Octane yet?
T.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
89, always
Randy Grant
Ellensburg, WA 98926
Ran 87 from Tucson to central Washington pulling a 9000 lb trailer, and averaged 10 mpg over hill and dale with a 5.7 e-torque. Haven't run a trip with 89, but will hve to give it a try to see what the difference is.
Matthew9227
Spencer
I have run 87 the whole time and I can say for sure that it has much more power on 89 (dealership filled with 89 before pickup)but the price difference is not worth it for extra horse that I won’t use anyway. As far as longevity it will be traded in by 50k so personally idc.
runamuck
dfw
6.7 dsl
I put 87. my wife has to use premium in her Infiniti so I figure it averages out for us. I dont even use premium in my harley as they suggest. never had any trouble with either.
Shaky Town
Boxford, MA
No matter what vehicle of mine, and all the manuals recommended 91, I always run 87.
- Yamaha MT07 motorcycle
- BMW r9T motorcycle
- BMW Z4 car
- Harley Softail Deluxe
I read an article a few years back in Cycle World magazine about fuel and octane. They said that the only reason to move up in octane is if your engine pings. Otherwise, 87 is legit. All the above vehicles run great on 87. The article also said that you would get the best gas mileage with 87, and just as much performance.
My Ram truck was just recently ordered, so nothing yet on that one. The Z4 loves the 87 nectar, ah ha.
Danielgetya
Only use 93. Keep the engine at optimal performance and I actually get better gas mileage I did a little survey in for me that’s what works
turkeybird56
Central Texas
Run 89 octane, and try to stay with high usage stations, not Mom and Pop.....
Fabian805
Ventura
I used 91 Shell Nitro and for me its the Best compared to Chevron with Techron. Feel my truck more responsive and super smooth @ idle
Elkman
Monterey
V6
Doesn't anyone know what the octane rating actually means? It is not a measure of the btu available from the fuel. It is only a measure of pre-ignition which results in engine knock which is damaging to the truck. The higher the compression ratio of an engine the more prone it is to pre-ignition of the gas when it first is injected into the hot cylinders of the engine. The higher the compression ratio the higher the recommended octane fuel that is recommended.
If a lower than recommended octane gas is used the computer will retard the spark automatically to compensate and try to prevent pre-ignition and engine knock. The result will be less power and probably fewer miles per gallon.
But if an engine is designed for 87 octane gasoline and one decides to put in a higher octane gas, then all they are doing is adding to the riches of the Koch brothers who already have billions of dollars and own our government so they do not need your charity. And with the money you save you can have the local tire shop put 100% nitrogen in the truck tires or invest in bitcoin.
UrWifesFavorite
Built to Grip & Ready to Rip
Washington for now but GUAM is Home
6.4 SRT
- BMW Z4 car
[emoji2357]
Sent from UrMoms House
buddy guy
alberta
87, not a tow truck for me, Ram runs fine on it. 13 cents a litre more for 89 it's not going to happen.
When I had my Victory Magnum bike, it was supposed to require 91 I think. Fk that noise unless it pinged on me.I ran 87 on it and unlike the Ram no built in timing retard to compensate. A proper tune for the engine did a better job than premium fuel ever would. I kept a bottle of Lucas octane booster with me on trips in case I ran into some questionable gas.
But to each their own!
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
- BMW Z4 car
Yea from ur list above ull b ok I have a few boosted items that need 93. My old truck had 3 different tunes on the fly and I could never tell the difference between the 87 and 93 tune- only the tow tune u could tell a difference because it still had the WOT restriction in place and the throttle sensitivity was dialed down
Zachary Williams
Brenham Texas
Laramie Sport 5.7 hemi 4wd
89 at least and ill usually go to murphys but will not go anymore generic than that!!! decnt price, decent gas.
