2011 randomly stalls
alnelson14
Cummins
My mom has a 2011 1500 with a 5.7 in it. Truck has 40,000 miles on it, and recently started shutting off at stop lights. So far, it has always fired right back up. However just now she said it started and sputtered when she took off. Truck continued to run. Oil is good. No check engine codes. Any suggestions on where to start? IAC?
A
alnelson14
Cummins
Reading more there is no IAC. She says the radio and lights stay on, just the engine shuts off. Im going to replace the battery (its original) tonight, clean the throttle body, and check the transmission fluid. Going to try these things before doing the ignition switch.
Burla
2010 Hemi Reg Cab 4x4
Original Battery?
RamCares
n/a
n/a
Hi @alnelson14 - If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your Ram dealer, please do not hesitate to follow up with us via private message. We would be more than happy to get you set up with a specialist for an additional layer of support for the dealer process.
Mark
RamCares
A
alnelson14
Cummins
I was going to say check throttle body as she may need a cleanin!
That was next on my list, but I solved it.
Original Battery?
Yessir. I will replace it before the temp drops again.
2011 w 40k miles??? Thats awesome.
Her and dad bought it brand new in 11. Pops passed in 2015 at 53 years young, and i talked her into moving closer to me. Shes quite the homebody. Dont think the trucks gotten 15,000 on it the last five years.
I'm embarrassed to say this. I hadnt had a chance to check anything on the truck before my post, but it was the air filter. It was original to the truck and when she would let off the throttle, it would just strangle the engine. Replaced it and it hasnt died again!
scott lass 18
rocklin ca
2010 ram 1500
mine at 60,000 stalling at stop light drops to 450 rpm jumps back up to 600 stealler says doesn't do it for them and don't hear ticking wow pretty sad there lost cuz was looking at 2019 to buy there not anymore ! has anyone try the disconnect battery and put both + and _ together one hour ? may try it ?
