Anybody ever check their upper intake bolts?
Jamerson
Mississippi
Done mine today. 2019 Ram classic. All were under specs. I went 20,40,60,80,95 then finally 108 in. lbs.
2 moved @ 20 in.lbs. [emoji15]Engine sounds quieter now.
U&A
2016 3500 SRW
6.4 HEMI
38,000 miles on my 6.4.
No loose bolts. [emoji2373]
I’d rather check them every oil change then put Loctite on them.
Sent while firmly grasping my redline lubed RAM [emoji231]
NY Andrew
VA
5.7L V8 Hemi
Was waiting until my oil/filter change and other maintenance to go around and finally check these. Below is my results ONLY AFTER 6,483 MILES!!!!! Can't even imagine going 36k and bummed I can't properly check a few of them! This was after two years; from now on I think I'll just check them every 2 years.
Didn’t tighten in the sequence because couldn't properly/comfortably access the passenger side bolts correctly due to Mopar CAI and Catch-Can. I attempted to re-torque each three times.
Drivers side:
All at least 20 inch-pounds loose, but 1 was good.
Passenger side:
7 was good
3 & 6 might have been a little loose
Couldn't reach 2 & 10
grizzstang
Calgary, Alberta Canada
Changed my oil and checked all my intake bolts today. All of mine were very loose. 2017 with less than 23,000 miles. Went around in sequence 3 times at a half turn each time until tight. I only torqued them to 85 inch pounds as I was afraid to crack the intake or the 3 year old gaskets. I will definitely check these again next oil change (10 months to a year) to see if they loosened off again.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Getting FCA to do anything is like getting that white Redline lubed ram on OCDTech’s sig to jump off that damn screen!
grizzstang
I was under the hood changing the air filter so i thought I would check the intake bolt torque after a week of driving. Sure enough they were almost a half turn loose again so I retorqued them to 90 in/lbs. From what I have read the bolts are not really loosening off. Several guys on a Challenger forum have torqued them, driven it for a month and retorqued them, then marked them. After driving for months and rechecking the marks, none moved. I think if you keep torquing them down eventually you will mash the intake seals and/or crack your intake. I think I will leave mine alone now since they have been done twice.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Déjà vu
4 years later….
Mister Luck
WEST COAST
5.7 V8
I think this should be made into a sticky at least until a better thread is created
