Everything Bilstein Mega Thread
R.L.K.
Bristol , Tn.
What he said ^^^^^^^^^^^^^^^
makodiver
35s
Do you have any rubbing issues? Did you get a certain offset with your wheels? Want to use stock 20 wheels but think I need atleast a 1/4" spacer. Any thoughts? Thanks
This was intended for HemiPower36...
nclark112
Jacksonville, NC
So I'm currently sitting at 2.1 and have decided I'd like to go to 2.8 and install some mevotechs ucas while I'm at it. Being the lazy ******* I am I was wondering if anyone has adjusted the shocks without having to take it all the way out. Or is that the only way to adjust it?
Sent from my SAMSUNG-SM-G891A using Tapatalk
WilliamS
Tampa FL
They have to come off, to get a spring compressor in there to get it high enough to change the perch I imagine would be impossible, if not more work than just taking it off.
nclark112
Jacksonville, NC
That's what I thought but figured it was worth a shot to ask.
makodiver
2011 1500 4x4 Bilstein all the way up. Question is. Do I need a wheel spacer to run 35x12.50r20 on stock 20inch wheels?
Sent from my SAMSUNG-SM-N900A using Tapatalk
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
It will partially depend on the brand of 35x12.5 that you want to run. But the safe answer is yes, you will need spacers. 10mm hub centric spacers from Motorsport Tech are the ones you'll want to go with.
makodiver
Sounds good. Thanks
nclark112
Jacksonville, NC
I agree itll depend on which tire but I can tell you I have Firestone destination m/t in 35x12.50r20 and they only rub at full turn.
MaxSteelRam
would changing out UCAs require a realignment? just thinking of staying with the stock ones for now, but if need be or money allows upgrade down the road.
makodiver
Yes.. get an alignment after you change them.
WilliamS
Tampa FL
I dont care what you do with the front end, if anything that is attached to anything that holds the wheels on the truck you need an alignment. Tie rods, control arms, ball joints, and everything else in there, just get it aligned. It does not take a whole lot by the eye to mess up bearing and good tires.
CORam2500
Bils on a 2500
Hi all,
Read all these posts and a bunch of others and could not find answers to my questions.
I have a 2010 2500.
Are the part numbers listed valid for a 2500?
Are they still hight adjustable for the 2500?
Any guidance on the height for a 2500?
Will they handle heavy loads?
Any experience with the ride quality improvements noticed on the 1500s with the 2500s?
Thanks!
R.L.K.
Bristol , Tn.
Hi all,
I have a 2010 2500.
Thanks!
You Sir have a straight front axle .... the 1500s have an IFS , Independent Front Suspension.
Pretty sure Bilstien has shocks for you , but not adjustable.
I believe you would install spacers for a level . If that's what your after .
MaxSteelRam
Bilsteins just came via amazon.ca. great price. now to get them on the truck, will need to make a service appointment since this is beyond my capabilities.
R.L.K.
Bristol , Tn.
Knowing your limits on capabilities is sometimes ones greatest attribute
Congrats on the bils Sir !
brandonjansen
Hi all,
I have a 2010 2500.
Thanks!
As RLK stated above, none of this information applies to you as the suspension design on your 2500 is completely different from at 1500.
Your best option for leveling is progressive rate leveling springs, longer shocks, and an adjustable track bar. I'd recommend Thuren Fabrication components for all of the above. That will get you the best riding setup for a good price.
MaxSteelRam
Truck just dropped off at shop to get Bilsteins put on.. excited :p
edit: Once I get it back, how do I know where to adjust headlights to? I understand how to adjust the headlights, but not sure how to measure or anything along those lines.
