AlfaOBD
Hudson
GA
Hey has anyone succesfully logged data in the android app. Trying to log the CVI values for my tranny and when I press the graph button nothing happens. Any tips would be appreciated
RamDiver
Marlborough, Ontario Canada
2021 DS
Switch to AlfaOBD for windoze. :cool:
I believe the default save location with AlfaOBD for Android is in the cloud, maybe google drive.
Hudson
GA
Thanks for the quick response. My ******* did not turn on csv datalogging file in settings of the alfa obd
For anyone else looking for it its under:
Set Preferences
Graphs and recording
Gauges Data recording
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Are you hitting the "play" triangle at the top?
Megas_XLT
Memphis
Please Read!!!
Supported years: 2013 to 2018
Make a backup of your original BCM configuration before making any changes. While we have a few BCM configs to compare with, there is nothing like comparing to your own pre-changes.
Instructions:
Uploading System ID (BCM) Information: Thank you Mpgrimm2
To upload your System ID information (BCM) go to the "Tools" icon in the upper right corner. From there select "Upload to Google Drive", it will ask you to link to Google Drive. Link your Google Drive to Alfa. Select "Upload to Google Drive" and "Upload Faults and Status Log". Then select "Body_Chrysler_Info". Name the file to upload whatever you wish. Done! Now you can go to your Google Drive and read the system info a little easier.
For viewing the information directly on the app, go to the bottom and select the battery icon once a connection has been made. Then select Read System ID. It should start populating below. Form what I have seen the Alfa programming tool keeps a record by date of all changes in the BCM from time of first connection.
WORKAROUND UNTIL DEV HAS FIXED POST #8734 and 8735 Thank you @enolS
Only make changes you are sure of.
There are quite a few setting in the AlfaOBD software that are just not for us Ram owners. What you will find in Alfa are code settings for most FCA vehicles. If it makes sense and if another Ram has it from factory, then chances are you can set it. You must also keep in mind not only code settings will get you what you want, you will also need the proper hardware installed. Alfa is not magical!!!
Hello all! Below is a list of known working codes when using AlfaOBD and the OBDLink MX Bluetooth with Android tablet/phone. This thread is to get the information out about this program/tool and its powerful interface. Ricks Ram, STecoD, Mpgrimm2 and I have been able to activate the following codes with no ill effect. I personally have been in contact with the developer several times and he is very willing to help and is pushing updates fairly regularly.
AlfaOBD is only available to Android and Windows platform. There is NO iPhone support.
AlfaOBD
https://play.google.com/store/apps/details?id=com.AlfaOBD.AlfaOBD
https://www.amazon.com/ScanTool-426101-OBDLink-Bluetooth-Professional/dp/B006NZTZLQ
MX vs MX+
***The MX+ is supposed to be slightly faster, comes with Enhanced Diagnostics Add-on and works with iOS devices. The price difference is only like $10. If you already have the MX the only major reason to change to the MX+ is if you want to use it with iOS(There is no AlfaOBD on iOS).*** Thanks @crash68
While there are other ways of connecting to your BCM with AlfaOBD, the above OBDII adapter has been tested and is preferred.
Before attempting any of this be sure to skim through the instructions/help pdf on getting started.
ANDROID http://www.alfaobd.com/AlfaOBD_Android_Help.pdf
WINDOWS http://alfaobd.com/AlfaOBD_Help.pdf
DeereGuy: In case anyone with a 2018 RAM would like to make changes to their truck, we have just officially announced a security bypass harness that will let alfaOBD and other tools work with the 2018s.
https://www.ramforum.com/threads/2018-ram-security-module-bypass.125133/#post-1801395
Please make notes for every code you set!!!
If there is a problem this will give you a starting point in which to go back and change what went wrong. We have found nothing in the codes listed below that is not reversible. While it is possible to select multiple codes at once, it is recommended to set one code at a time then let the truck sleep 3 to 5 minutes. When I first started this I noticed some of my codes didn't take right away. I believe it is because I was not giving it enough time.
Known Working List This link provides a working list of codes that will be updated periodically with new additions.
Write-ups for a few of the commonly sought after changes in Alfa. Thank you @1500ram12
Confirmation of DRL CSM showing on RA2 radio settings.
Original Post by @G-Ride990 ... Here and Here
Thank you @ramrocker for locating the above!
Shared BCM Configurations
Earlier Versions of AlfaOBD Thank you @Lawsuit11
Index of How To's and info: Thank you to all those who have contributed!!!
Android getting started
Windows getting started
Tire size adjustments (Easy online calculator)
TPMS
Fob Programming Walk Through
Obtaining 4 digit pin from reluctant dealer
Differences on 4 and 5 digit pin code.
Mirror info for tilt in reverse function
Adding Rain Sense Wipers
Adding OEM Cargo Camera with M2Mods Harness
BW 44-44 to BW 44-45 Transfer Case Swap
2006-2012 Thread on Alfa usage
Factory Keyless Enter N Go
Remove Air Suspension Warning (Disables air suspension)
Adding Dual Zone ATC to a Tradesman
Heated/Vented Seats and Wheel Posts 6959 to 6968
Adding Front LED Turn/Park Lamps
Odometer Correction Post 7871 Thanks @Lawsuit11 (Proceed at your own risk! Still not perfect as the correction is slightly off in the tenths)
Engine Hour Correction Post 7910 Thanks @Lawsuit11 (Proceed at your own risk!)
Do not use an app called SRTactivator. It could possibly leave your truck inoperable or at very least needing to have the BCM flashed at the dealer. It is strongly advised to not change the "Vehicle Line" or "Vehicle Brand". Be very careful in making changes to settings you are unsure of or that have not been tested.
FYI - AlfaOBD needs to be connected to your truck in order for you to be able to see all the settings. While most of them will show, you will not have several other as well as all the CSMs.
Ricks Ram: "I wanted to mention it might be a good idea for guys to leave positive comments in the Google Play Store or wherever you buy the alphaOBD tool from and mention that you're using it for your RAM so the developer will see how many of us who are using the tool are from the Ram community. I'm thinking it might help us in the future as he refines a tool when he knows how many guys are using it for Ram trucks since it was primarily used for Alfa Romeos and other cars prior to the Ram pickup.
I'll continue to update as I find new working codes or fixes to issues as given to me.
Special thanks out to Ricks Ram, STecoD and Mpgrimm2!! I don't believe I missed anything here but if I did, please let me know and I will edit. Thanks!
I have a 2015 ram 2500 with the 5.7 Hemi recently I swap my transmission and I just bought this transmission from a 2018 Ram 3500 both of them are two wheel drive I finally put in my new transmission to it it runs great but I noticed that sometime it will downshift hard and I'm kind of worried that if I don't get this taken care so I have the device but it seemed I can't find or I don't know where I need to go to find a setting to relearn the transmission so hopefully if you can help
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Try these steps. I am using windows version so will look different, but you should get the idea:
The AlfaOBD also have the VIN write feature for the transmissions, so don't forget that.
Me, not knowing exactly what you have, I am showing my '16 1500. I looked thru the 2500 and 3500 pages and this stuff is in there, too.
Select your truck model and xmission type:
Click on active diagnosis
Click on reset adaptive values: (This should be done prior to quick learn)
Go to quick learn and follow the directions
Hope this helps
Megas_XLT
Memphis
Hope this helps
Thank you I'm going to go ahead and try that once I get off of work and I'll let you know if it doesn't work I might just say screw it then just go ahead and buy the window ver but you do need any more detail about my truck let me know
Megas_XLT
Memphis
Megas_XLT
Memphis
Hope this helps
I appreciate your help but none of them even working it keeps saying fail connected and I have reset it multiple time I probably just wait till I try to see if I can buy the window version cuz it ain't working on the Android
RamDiver
2021 DS
After selecting your brand, model, function and transmission, the next step is to connect, before clicking the open hood.
After a successful connection, then click the open hood for active diagnostic.
Is that the process you have been following?
I also use AlfaOBD for windoze but I believe the directions I've posted here are correct for the Android version.
04fxdwgi
2016 1500 Sport
Send Alexi (the AlfaOBD developer) a note and he will give you a code it enter when re-installing on a windows Pc, so you won't have to buy it again.
Me thinks it is an issue between the phone / tablet and the dongle. There may be a setting in the phone that is preventing connection,
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Have you paired your Android device to the Bluetooth OBDII adapter?
Megas_XLT
Memphis
No I think I need to purchase the window version of it I don't know if the issue with my phone communicating the dongle
Reticle918
